Scratch that - I have now got it to work okay in 12.3 and it's ripping fine.
Quite baffled
Incredibles 2 BD
Re: Incredibles 2 BD
Well, you got a good copy. If it were me, I'd save a copy of the debug log, blame it on this disc & move on. If it happens again on another disc, send both logs to Mike with a description of the problem. Or wait to see if this hits his radar & he responds here? YMMV
jjslegacy
Agreed.
I do now see av sync issues which I never had that option turned on so I decided to today:
AV sync issue in stream 1,2,3,4 at 0:23:33.412 with duration of 3.708ms : encountered overlapping frame, audio skew is +6.666ms
AV sync issue in stream 1,2,3,4 at 0:23:50.345 with duration of 5.083ms : encountered overlapping frame, audio skew is +11.75ms
AV sync issue in stream 1,2,3,4 at 0:23:50.357 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.083ms
AV sync issue in stream 1,2,3,4 at 0:25:30.529 with duration of 8.583ms : encountered overlapping frame, audio skew is +9.666ms
AV sync issue in stream 1,2,3,4 at 0:25:49.297 with duration of 4.583ms : encountered overlapping frame, audio skew is +14.25ms
AV sync issue in stream 1,2,3,4 at 0:25:49.312 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.583ms
AV sync issue in stream 1,2,3,4 at 0:28:59.571 with duration of 9.25ms : encountered overlapping frame, audio skew is +12.833ms
AV sync issue in stream 1,2,3,4 at 0:28:59.584 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.166ms
AV sync issue in stream 1,2,3,4 at 0:29:37.108 with duration of 9.166ms : encountered overlapping frame, audio skew is +11.333ms
AV sync issue in stream 1,2,3,4 at 0:29:37.120 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 1,2,3,4 at 0:31:20.003 with duration of 6.875ms : encountered overlapping frame, audio skew is +7.541ms
AV sync issue in stream 1,2,3,4 at 0:34:21.267 with duration of 4.916ms : encountered overlapping frame, audio skew is +12.458ms
AV sync issue in stream 1,2,3,4 at 0:34:21.280 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.791ms
AV sync issue in stream 1,2,3,4 at 0:35:10.900 with duration of 9.75ms : encountered overlapping frame, audio skew is +11.541ms
AV sync issue in stream 1,2,3,4 at 0:35:10.912 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.875ms
not sure if that is randomly normal or not but I do see another user who reported that
See my response. It's due to seamless branching. I see the msgs as unnecessary noise... unless debugging a specific A/V sync issue. Again, YMMV
jjslegacy
was just reading that - had never turned it on - I think I will turn it back off
Thanks for all the help
I upgraded to 14.1 and tried again and it worked.
I haven't a clue....
YouWho
I also had issues with this disk on v1.14.1 (Mac version). Aborted the first indexing read because it was still cranking (literally the drive sounded sick) after 35 minutes. Restored version 1.12.3, worked like a charm - done in 4 mins or so.adampk17 wrote: Sat Nov 10, 2018 12:49 am Does not appear to be fixed in 1.14.1. It's still chewing on opening the the disc 11 minutes later and less than 50% done.
Issues seem to still be plaguing 1.14.1.
thirstyspider
I'm trying to get the Redbox version and I get these errors. I'm making the 0080 .mpls source file.
Anyone have any suggestions? I'm running 1.14.2 on MacOS 10.14.2 (Mojave)
Thanks anyone that can help.
_________________________________________________________
Saving 1 titles into directory /Volumes/passport
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00820.m2ts' at offset '53213184'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '53213184'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00820.m2ts' at offset '53219328'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '53219328'
Failed to save title 3 to file /Volumes/passport/Incredibles 2_t03.mkv
Encountered 12 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
garretn
Try cleaning the disc. That happens to me sometimes even on brand new, directly out of the package, discs. Being from Redbox, I'd say the likelihood of that being the problem jumps about a million percent.
thirstyspider
Thanks for your reply.
Rookie mistake by me. I always inspect the disc first, and missed this one. Cleaned it, but there's a couple scratches on the disc, so probably won't be able to finish - I'm on the third attempt. Not surprised it's damaged considering it's a kids film. And I thought BD discs were supposed to be really hard to damage.
In reality, BDs are much more fragile than DVDs, if only because they require more precise focus to read.
Something I reserve for borderline disks - Pledge furniture polish. It's water-based, so it doesn't damage the surface, it is good at cutting through fingerprints, and it fills in minor scratches enough that many disks can be read at least once.
Spray it on, rub it in with a clean finger (circular motion!) until it starts to get sticky, then buff it off with a clean, soft cotton cloth. Work radially (across the disk, not going around the disk) with the cloth. As soon as it is dry, rip it.
It's worked for me with kid-tested disks.
thirstyspider
I just happen to have a can of lemon Pledge
But alas, it’s not working. Thank you for the suggestion. While the disc is remarkably clean, it still won’t rip. I’ll definitely try the Pledge trick again.
