Incredibles 2 BD
gsydnor
Incredibles 2 BD
#1 Post by gsydnor » Tue Nov 06, 2018 11:32 pm
makemkv v 1.14 hangs at about 25 % point when it is analyzing the disk. I stopped it at 12 minutes.When I rolled back to V 12.3,it reads the disk fine.
BWStephens
Re: Incredibles 2 BD
#2 Post by BWStephens » Wed Nov 07, 2018 1:44 am
Same here. I tried to use the DVD instead and the same thing happened.
I updated MakeMKV and now I don't know how to roll it back so I'm stuck until the next update I suppose.
#3 Post by d00zah » Wed Nov 07, 2018 2:52 am
Use link to old versions in my sig.
cyberdman
#4 Post by cyberdman » Wed Nov 07, 2018 11:36 pm
I too am having a ton of problems trying to rip Incredibles 2 with the new version 1.14.0.
Thanks for the links d00zah, but you don't have the setup for 1.12.3. :(
#5 Post by d00zah » Wed Nov 07, 2018 11:43 pm
Not me. That's the 'official' archive. Perhaps a note to support@makemkv.com will get it added? Me, I always hold on to 1-2 previous versions (just in case).
smartieyoung
#6 Post by smartieyoung » Thu Nov 08, 2018 12:38 am
going to add this new version of make mkv might still have a few kinks to be ironed out.i have tried and was able to successfully backup mayhem to my computer with no problems.going to try action point next putting new version though its paces :wink:
BWStephens
#7 Post by BWStephens » Thu Nov 08, 2018 1:48 am
Thanks, d00zah. I rolled back to 1.12.2 and it seems to be working fine now.
Thanks for the advice. I'm going to start keeping old versions myself. Appreciate the feedback.
#8 Post by mike admin » Fri Nov 09, 2018 9:14 am
Should be fixed in 1.14.1
adampk17
#9 Post by adampk17 » Sat Nov 10, 2018 12:49 am
Does not appear to be fixed in 1.14.1. It's still chewing on opening the the disc 11 minutes later and less than 50% done.
adampk17
#10 Post by adampk17 » Sat Nov 10, 2018 1:10 am
I take this back. I had a second instance of MakeMKV open ripping another movie at the same time I was attempting to open Incredibles 2. I have two optical drives. This doesn't normally cause me issues but it sure did this time. Once the other movie finished ripping MakeMKV opened Incredibles 2 without issue.
zombiehorde
#11 Post by zombiehorde » Sat Nov 10, 2018 8:59 pm
I updated to 1.14.1 because it was taking too long to rip the 800 title. Now, however, I'm getting AV Sync issues out the wazoo.
  • AV synchronization issues were found in file 'C:/M2TS/Incredibles 2_t02.mkv' (title #3)
    AV sync issue in stream 1,2,3,4,5,6,7 at 0:01:09.402 with duration of 5.333ms : encountered overlapping frame, audio skew is +5.333ms
    AV sync issue in stream 1,2,3,4 at 0:03:05.226 with duration of 5.291ms : encountered overlapping frame, audio skew is +10.625ms
    AV sync issue in stream 5,6,7 at 0:03:05.226 with duration of 15.958ms : encountered overlapping frame, audio skew is +21.291ms
    AV sync issue in stream 5,6,7 at 0:03:22.327 with duration of 19.583ms : encountered overlapping frame, audio skew is +40.875ms
    AV sync issue in stream 5,6,7 at 0:03:22.368 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +8.875ms
    AV sync issue in stream 1,2,3,4 at 0:03:22.327 with duration of 8.916ms : encountered overlapping frame, audio skew is +19.541ms
    AV sync issue in stream 1,2,3,4 at 0:03:22.346 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +8.875ms
    AV sync issue in stream 1,2,3,4,5,6,7 at 0:04:45.326 with duration of 8.416ms : encountered overlapping frame, audio skew is +17.291ms
    AV sync issue in stream 1,2,3,4 at 0:04:45.344 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +6.625ms
    AV sync issue in stream 1,2,3,4 at 0:05:09.684 with duration of 5ms : encountered overlapping frame, audio skew is +11.625ms
    AV sync issue in stream 1,2,3,4 at 0:05:09.696 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.958ms
    AV sync issue in stream 5,6,7 at 0:05:09.684 with duration of 26.333ms : encountered overlapping frame, audio skew is +43.625ms
    AV sync issue in stream 5,6,7 at 0:05:09.728 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.625ms
    AV sync issue in stream 5,6,7 at 0:08:53.616 with duration of 3.958ms : encountered overlapping frame, audio skew is +15.583ms
    AV sync issue in stream 1,2,3,4 at 0:08:53.616 with duration of 3.958ms : encountered overlapping frame, audio skew is +4.916ms
    AV sync issue in stream 1,2,3,4 at 0:09:09.674 with duration of 6.291ms : encountered overlapping frame, audio skew is +11.208ms
    AV sync issue in stream 1,2,3,4 at 0:09:09.685 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.541ms
    AV sync issue in stream 5,6,7 at 0:09:09.674 with duration of 6.291ms : encountered overlapping frame, audio skew is +21.875ms
    AV sync issue in stream 1,2,3,4 at 0:15:06.780 with duration of 2.583ms : encountered overlapping frame, audio skew is +3.125ms
    AV sync issue in stream 5,6,7 at 0:15:06.780 with duration of 13.25ms : encountered overlapping frame, audio skew is +35.125ms
    AV sync issue in stream 5,6,7 at 0:15:06.816 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.125ms
    AV sync issue in stream 1,2,3,4 at 0:15:21.629 with duration of 10.5ms : encountered overlapping frame, audio skew is +13.625ms
    AV sync issue in stream 1,2,3,4 at 0:15:21.642 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.958ms
    AV sync issue in stream 5,6,7 at 0:15:21.629 with duration of 31.833ms : encountered overlapping frame, audio skew is +34.958ms
    AV sync issue in stream 5,6,7 at 0:15:21.664 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.958ms
    AV sync issue in stream 1,2,3,4 at 0:23:33.412 with duration of 3.708ms : encountered overlapping frame, audio skew is +6.666ms
    AV sync issue in stream 5,6,7 at 0:23:33.412 with duration of 25.041ms : encountered overlapping frame, audio skew is +28ms
    AV sync issue in stream 1,2,3,4 at 0:23:50.345 with duration of 5.083ms : encountered overlapping frame, audio skew is +11.75ms
    AV sync issue in stream 1,2,3,4 at 0:23:50.357 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.083ms
    AV sync issue in stream 5,6,7 at 0:23:50.345 with duration of 26.416ms : encountered overlapping frame, audio skew is +54.416ms
    AV sync issue in stream 5,6,7 at 0:23:50.400 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +22.416ms
    AV sync issue in stream 1,2,3,4 at 0:25:30.529 with duration of 8.583ms : encountered overlapping frame, audio skew is +9.666ms
    AV sync issue in stream 5,6,7 at 0:25:30.529 with duration of 8.583ms : encountered overlapping frame, audio skew is +31ms
    AV sync issue in stream 1,2,3,4 at 0:25:49.297 with duration of 4.583ms : encountered overlapping frame, audio skew is +14.25ms
    AV sync issue in stream 1,2,3,4 at 0:25:49.312 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.583ms
    AV sync issue in stream 5,6,7 at 0:25:49.297 with duration of 15.25ms : encountered overlapping frame, audio skew is +46.25ms
    AV sync issue in stream 5,6,7 at 0:25:49.344 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +14.25ms
    AV sync issue in stream 5,6,7 at 0:28:59.571 with duration of 30.583ms : encountered overlapping frame, audio skew is +44.833ms
    AV sync issue in stream 5,6,7 at 0:28:59.616 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.833ms
    AV sync issue in stream 1,2,3,4 at 0:28:59.571 with duration of 9.25ms : encountered overlapping frame, audio skew is +12.833ms
    AV sync issue in stream 1,2,3,4 at 0:28:59.584 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.166ms
    AV sync issue in stream 5,6,7 at 0:29:37.108 with duration of 30.5ms : encountered overlapping frame, audio skew is +43.333ms
    AV sync issue in stream 5,6,7 at 0:29:37.152 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.333ms
    AV sync issue in stream 1,2,3,4 at 0:29:37.108 with duration of 9.166ms : encountered overlapping frame, audio skew is +11.333ms
    AV sync issue in stream 1,2,3,4 at 0:29:37.120 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.666ms
    AV sync issue in stream 1,2,3,4 at 0:31:20.003 with duration of 6.875ms : encountered overlapping frame, audio skew is +7.541ms
    AV sync issue in stream 5,6,7 at 0:31:20.003 with duration of 17.541ms : encountered overlapping frame, audio skew is +28.875ms
    AV sync issue in stream 1,2,3,4 at 0:34:21.267 with duration of 4.916ms : encountered overlapping frame, audio skew is +12.458ms
    AV sync issue in stream 1,2,3,4 at 0:34:21.280 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.791ms
    AV sync issue in stream 5,6,7 at 0:34:21.267 with duration of 15.583ms : encountered overlapping frame, audio skew is +44.458ms
    AV sync issue in stream 5,6,7 at 0:34:21.312 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.458ms
    AV sync issue in stream 5,6,7 at 0:35:10.900 with duration of 31.083ms : encountered overlapping frame, audio skew is +43.541ms
    AV sync issue in stream 5,6,7 at 0:35:10.944 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.541ms
    AV sync issue in stream 1,2,3,4 at 0:35:10.900 with duration of 9.75ms : encountered overlapping frame, audio skew is +11.541ms
    AV sync issue in stream 1,2,3,4 at 0:35:10.912 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.875ms
    AV sync issue in stream 1,2,3,4 at 0:40:21.502 with duration of 0.708ms : encountered overlapping frame, audio skew is +1.583ms
    AV sync issue in stream 5,6,7 at 0:40:21.502 with duration of 22.041ms : encountered overlapping frame, audio skew is +33.583ms
    AV sync issue in stream 5,6,7 at 0:40:21.536 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.583ms
    AV sync issue in stream 1,2,3,4 at 0:40:42.064 with duration of 3.125ms : encountered overlapping frame, audio skew is +4.708ms
    AV sync issue in stream 5,6,7 at 0:40:42.064 with duration of 13.791ms : encountered overlapping frame, audio skew is +15.375ms
    AV sync issue in stream 1,2,3,4 at 0:42:07.191 with duration of 3.958ms : encountered overlapping frame, audio skew is +8.666ms
    AV sync issue in stream 5,6,7 at 0:42:07.191 with duration of 25.291ms : encountered overlapping frame, audio skew is +40.666ms
    AV sync issue in stream 5,6,7 at 0:42:07.232 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +8.666ms
    AV sync issue in stream 1,2,3,4,5,6,7 at 0:42:26.544 with duration of 7.333ms : encountered overlapping frame, audio skew is +16ms
    AV sync issue in stream 1,2,3,4 at 0:42:26.560 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +5.333ms
    AV sync issue in stream 5,6,7 at 0:44:31.669 with duration of 27ms : encountered overlapping frame, audio skew is +43ms
    AV sync issue in stream 5,6,7 at 0:44:31.712 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11ms
    AV sync issue in stream 1,2,3,4 at 0:44:31.669 with duration of 5.666ms : encountered overlapping frame, audio skew is +11ms
    AV sync issue in stream 1,2,3,4 at 0:44:31.680 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.333ms
    AV sync issue in stream 1,2,3,4 at 0:44:51.146 with duration of 10.208ms : encountered overlapping frame, audio skew is +10.541ms
    AV sync issue in stream 5,6,7 at 0:44:51.146 with duration of 10.208ms : encountered overlapping frame, audio skew is +21.208ms
    AV sync issue in stream 1,2,3,4 at 0:46:36.627 with duration of 2.291ms : encountered overlapping frame, audio skew is +12.833ms
    AV sync issue in stream 1,2,3,4 at 0:46:36.640 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.166ms
    AV sync issue in stream 5,6,7 at 0:46:36.627 with duration of 23.625ms : encountered overlapping frame, audio skew is +44.833ms
    AV sync issue in stream 5,6,7 at 0:46:36.672 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.833ms
    AV sync issue in stream 1,2,3,4 at 0:47:17.751 with duration of 6.25ms : encountered overlapping frame, audio skew is +8.416ms
    AV sync issue in stream 5,6,7 at 0:47:17.751 with duration of 27.583ms : encountered overlapping frame, audio skew is +40.416ms
    AV sync issue in stream 5,6,7 at 0:47:17.792 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +8.416ms
    AV sync issue in stream 1,2,3,4 at 0:48:53.889 with duration of 0.958ms : encountered overlapping frame, audio skew is +9.375ms
    AV sync issue in stream 5,6,7 at 0:48:53.889 with duration of 22.291ms : encountered overlapping frame, audio skew is +30.708ms
    AV sync issue in stream 1,2,3,4 at 0:50:39.494 with duration of 5.166ms : encountered overlapping frame, audio skew is +14.541ms
    AV sync issue in stream 1,2,3,4 at 0:50:39.509 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.875ms
    AV sync issue in stream 5,6,7 at 0:50:39.494 with duration of 26.5ms : encountered overlapping frame, audio skew is +57.208ms
    AV sync issue in stream 5,6,7 at 0:50:39.552 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +25.208ms
    AV sync issue in stream 1,2,3,4 at 0:54:45.490 with duration of 9.583ms : encountered overlapping frame, audio skew is +13.458ms
    AV sync issue in stream 1,2,3,4 at 0:54:45.504 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.791ms
    AV sync issue in stream 5,6,7 at 0:54:45.490 with duration of 20.25ms : encountered overlapping frame, audio skew is +45.458ms
    AV sync issue in stream 5,6,7 at 0:54:45.536 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.458ms
    AV sync issue in stream 1,2,3,4 at 0:55:06.511 with duration of 3ms : encountered overlapping frame, audio skew is +5.791ms
    AV sync issue in stream 5,6,7 at 0:55:06.511 with duration of 3ms : encountered overlapping frame, audio skew is +16.458ms
    AV sync issue in stream 1,2,3,4 at 0:56:36.101 with duration of 10.5ms : encountered overlapping frame, audio skew is +16.291ms
    AV sync issue in stream 1,2,3,4 at 0:56:36.117 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +5.625ms
    AV sync issue in stream 5,6,7 at 0:56:36.101 with duration of 10.5ms : encountered overlapping frame, audio skew is +26.958ms
    AV sync issue in stream 1,2,3,4 at 0:57:21.312 with duration of 4.166ms : encountered overlapping frame, audio skew is +9.791ms
    AV sync issue in stream 5,6,7 at 0:57:21.312 with duration of 4.166ms : encountered overlapping frame, audio skew is +31.125ms
    AV sync issue in stream 1,2,3,4 at 0:57:50.258 with duration of 3.75ms : encountered overlapping frame, audio skew is +13.541ms
    AV sync issue in stream 1,2,3,4 at 0:57:50.272 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.875ms
    AV sync issue in stream 5,6,7 at 0:57:50.258 with duration of 14.416ms : encountered overlapping frame, audio skew is +45.541ms
    AV sync issue in stream 5,6,7 at 0:57:50.304 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.541ms
    AV sync issue in stream 5,6,7 at 0:58:26.961 with duration of 0.666ms : encountered overlapping frame, audio skew is +14.208ms
    Too many AV synchronization issues in file 'C:/M2TS/Incredibles 2_t02.mkv' (title #3) , future messages will be printed only to log file
Is anyone else having this problem?
#12 Post by d00zah » Sat Nov 10, 2018 9:27 pm
From elsewhere on the interweb...
"... as is often the case with movies composed of several m2ts files (seamless branching), MakeMKV has to drop frames every so often to account for audio sync issues."
jjslegacy
#13 Post by jjslegacy » Mon Nov 12, 2018 1:17 am
Mine is doing something different I haven't seen before.
It seems to read the disc fine and I see
Operation Successfully Completed
While it tries to go back to the screen to show me the titles it hangs for a bit. I then get a popup saying: Fatal error occurred, program will now exit"
I can see all the titles and all looks good but clicking OK of course kills the app.
This seems to happen with 12.2 and 12.3 also.
Never seen this before hmm
#14 Post by d00zah » Mon Nov 12, 2018 1:40 am
You don't provide much to go on.
This disc only?
Does anything show up in the log with "log debug messages" enabled (general tab)?
What version? v1.4.0 included a bugfix for "MakeMKV could hang at the very end of MKV file creation in some rare cases".
jjslegacy
#15 Post by jjslegacy » Mon Nov 12, 2018 1:43 am
Sorry was multitasking and gathering some info.
This is the only disc I have ever had a failure from. I have ripped hundreds or more.
Versions I tried
14.1
12.3
12.2
All seem to show something similar.
I turned the debugging on but it doesn't show much after the read (opening of the disc) was successful just:
003309:0000 Title 00099.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00710.mpls is equal to title 00700.mpls and was skipped
csf8=1
csf7
Application exited at Mon Nov 12 01:41:09 2018
*Also noticed going into preferences also randomly causes it to crash and then the preference window pops up filled with some garbage. This seems to happen with the disc in. Now when I take out the disc - even more odd
