[this is a duplicate to a question i made in the mac os forum in error to an old thread - cant see how to delete the post]
I'm a bit confused here. I'm using linux and the log shows it finds java but it never identifies the correct play list even though others with the same disk have posted on this forum that it works for them (I think they used windows). What it shows in the log is:
Found java version=1.8.0.191 path=/usr/bin/... and path=/usr/lib/jvm/...
I see no other errors yet it doesn't identify the correct play list on disks where this is known to work. Is there something I should be looking for in the log (which does not seem to show any errors or issues) ?
Getting java to identify the correct playlist ?
jojo1
