SATA > USB data cables and external power adapters
jonghotti
Post by jonghotti »
jonghotti
Re: SATA > USB data cables and external power adapters
Post by jonghotti »
Post by d00zah »
Sincerely NOT trying to spin you back up after successful venting, but the Sabrent adapter bills itself as a "USB 3.0 TO SATA/IDE Hard Drive Converter". Although I didn't see it mentioned in manual (pretty picture book, actually... they don't make manuals like they used to), some of these adapters don't do ATAPI devices (ODDs), & I'll wager this is one of 'em. When shopping, look for specific mention of ATAPI/ODD support & save yourself an ulcer.
jonghotti
Post by jonghotti »
jonghotti
Post by jonghotti »
Oh Jesus H. Christ on a popsicle stick nowhere does this mention ATAPI support.
That’s why this shit doesn’t work.
Post by d00zah »
Fair cop... no 2 docs alike. UHD should still speak ATAPI. Bad drive? Bum connection? Solar flares?
Post by d00zah »
jonghotti wrote:
Fri Nov 09, 2018 6:42 pm
'CD/DVD-RW Drives' = ATAPI, but maybe they don't label it as such nowadays? Might be showing my age... sigh.
jonghotti
Post by jonghotti »
Most of the adapters I've played with suck in one way or another. I've used USB2 and USB3 to eSATA, USB2 to SATA and IDE, and even eSATA to USB, and all of them had quirks that made things worse.
I now use hot-swap tray-less SATA drive bays, and have extension cables that let me plug 5.25" devices in to them.
Which reminds me, I was going to order another hot-swap bay for the "handbrake" machine I'll be building when FedEx decides to deliver my new motherboards...
fishman
Post by fishman »
Hey woodstock
Do you have a link to the hot swap bays you use?
Good question - they keep changing the company names on them. :roll:
For hard drives, I've used 3, 4, and 5 bay internal units from StarTech, and private label versions of them. But, if you look for them on Amazon, the ones I've had excellent luck with get low ratings because of things like "too easy to open".
For USB connected units, I've also used StarTech. Those are the ones I plug the "SATA extension" cables in to when I need to talk to an optical drive. But I haven't done that in years... (the StarTech two-drive duplicator comes in handy when building multiple machines)
