Logitec LBD-VA6U3VRD
nano22
Post by nano22 » Tue Nov 06, 2018 4:23 pm
Backup was not possible with Logitec LBD-VA 6U 3 VRD Blu-ray Drive.
My environment
iMac (27-inch, Mid 2011)
CPU: 3.4 GHz Intel Core i 7
RAM: 16 GB 1333 MHz DDR 3
GPU: AMD Radeon HD 6970 M 1024 MB
MakeMKV Info
Manufacturer: PIONEER
Product: BD-RW BDR-UD 04
Revision: 1.10
Serial number: RFDL 072951 WL
Bus encryption flags: 1 B
Highest AACS version: 65
Disc Information
Label: DEADPOOL
Timestamp: 2016-07-13 16: 07: 31
Data capacity: 53.73 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
message
Can not read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Saved AACS dump file as /Users/nano/Movies/backup/MKB20_v60_DEADPOOL_960E.tgz
The volume key is unknown for this disc - video can not be decrypted
Backup failed
Re: Logitec LBD-VA6U3VRD
Post by Woodstock » Tue Nov 06, 2018 6:17 pm
Most likely, you've recently inserted a disk with v66 of AACS protection on it, and your drive will no longer listen to MakeMKV.
You may find a file in your MakeMKV directory with a name that starts with "MKB_v66". If so, please send it to support@makemkv.com for analysis.
If this is what happened, you will be able to rip DVDs, but BDs will not work until Mike releases a new version of MakeMKV that has a new application key.
st4evr
Post by st4evr » Tue Nov 06, 2018 6:41 pm
Revision: 1.10
Disc Information
Label: DEADPOOL
Number of layers: 2
Backup failed
That is NOT an compatible drive to backup/rip UHD BDs. You need to read this:
viewtopic.php?f=16&t=16832
this:
viewtopic.php?f=12&t=16883
this:
viewtopic.php?f=16&t=17092&p=60792&hili ... ver#p60673
and this:
https://www.myce.com/news/the-ultimate- ... ive-83254/
If more information is needed searching the forum and Google will also yield hundreds of more posts/discussions on this subject as well.
jonghotti
What you need to do
Post by jonghotti » Wed Nov 07, 2018 9:06 pm
Is email me alexcoluzzi32@gmail.com for a drive that’s guaranteed to be compatible with MakeMKV
Do This though only after purchasing a license key for MakeMKV and prove to me you’ve done that and I’ll make a smoking deal on a drive.
Thanks,
Alex
