MakeMKV 1.14 problem
wjindg
Post by wjindg » Wed Nov 07, 2018 5:31 am
MakeMKV 1.14 failed to convert two disks that I did convert by reverting to version 1.12.0. The drive hangs up trying to read over and over. Log is attached. Mac OS 12.6
MakeMKV_log.txt
(28.48 KiB) Downloaded 892 times
Re: MakeMKV 1.14 problem
Post by Woodstock » Wed Nov 07, 2018 3:06 pm
Send an email to support@makemkv.com with a link tot his topic, to make sure Mike sees it sooner.
Post by mike admin » Thu Nov 08, 2018 11:32 am
Appears to be a bug in 1.14.0 . Please send testdump per instructions at http://www.makemkv.com/onlinehelp/testdump.html , this would help a lot. Thanks!
Post by mike admin » Fri Nov 09, 2018 9:16 am
Fixed in 1.14.1
greginpa
Post by greginpa » Tue Nov 13, 2018 12:12 am
I have an internal dvd drive in my mac and was borrowing an external blu-ray player from my brother. I experienced the slow (lots of reads) problem using the blu-ray drive on some discs with 1.14.0 but 1.14.1 fixed that problem. I gave the blu-ray drive back and was trying to use 1.14.1 with my internal dvd drive. Makemkv sees the disc and content fine, but when i hit the makemkv button after a tiny bit of activity makemkv just kinda sits there doing nothing. It isn't constantly spinning up the drive, like 1.14.0 did with blu-rays. It appears to be doing nothing. No drive sound. I waited over 9 minutes, nothing. I tried 1.14.1 with two discs that I've done before with makemkv, same results. Installed 1.14.0 again, tried same discs, same nothing. I installed 1.12.3, boom, instant file creation with 1.12.3.
I installed 1.14.1 again, using the same disc as used in 1.12.3 above, it is paused at output size of 7.6k after 7 minutes of time.
1.14.1 seems to work with some dvds for me, but i have identified 2 dvd so far, with little testing, that 1.14.1 just doesn't seem to act on.
Any questions just ask.
Thanks,
Greg
boogy886
Post by boogy886 » Sat Feb 23, 2019 2:29 am
Running into the same issue with some disks in 1.14.1 and 1.14.2 in Ubuntu, but a quick search came up with this thread
