The Fog UHD 4K - Rips in 1.12.3, but not 1.14.0
stuckinkodiagain
I just got John Carpenter's "The Fog" in 4K UHD from the UK. I opened it in MakeMKV version 1.12.3, and it decrypted the disc just dine. But then I saw MakeMKV was updated to version 1.14.0. So I quit out, updated it, re-opened MakeMKV, and tried to decrypt the disc again... and it failed.
I've since reverted back to version 1.12.3, and all is well. But wanted to let you guys know that something funky is going on with the 1.14.0 decryption.
Re: The Fog UHD 4K - Rips in 1.12.3, but not 1.14.0
im going to try a few 4K bulrays now and report my success/ failure
update:
well all the disks i tried still work here is a list of them
Jurassic World Fallen Kingdom
Wonder Woman
The Mummy
The Mummy returns
and there maybe wh16ns60 support? a drive cross flashed to it worked
update:
Wonder Woman
The Mummy
The Mummy returns
- Contact:
Please send the log file to suport@makemkv.comstuckinkodiagain wrote: Wed Nov 07, 2018 3:40 am I just got John Carpenter's "The Fog" in 4K UHD from the UK. I opened it in MakeMKV version 1.12.3, and it decrypted the disc just dine. But then I saw MakeMKV was updated to version 1.14.0. So I quit out, updated it, re-opened MakeMKV, and tried to decrypt the disc again... and it failed.
stuckinkodiagain
Will send later tonight!mike admin wrote: Wed Nov 07, 2018 6:15 pmPlease send the log file to suport@makemkv.comstuckinkodiagain wrote: Wed Nov 07, 2018 3:40 am I just got John Carpenter's "The Fog" in 4K UHD from the UK. I opened it in MakeMKV version 1.12.3, and it decrypted the disc just dine. But then I saw MakeMKV was updated to version 1.14.0. So I quit out, updated it, re-opened MakeMKV, and tried to decrypt the disc again... and it failed.
Same with Incredibles and Wreck-it Ralph and possibly others.
stuckinkodiagain
Strange... There seemed to be another update today to MakeMKV, even though it had the same version number (1.14.0). I downloaded it anyway, installed, and now "The Fog" (and several other recent UHD releases like "Wreck-It Ralph," "Incredibles 2," and "Superman: The Movie") are working fine in the latest version.
- Contact:
There was no other update...
I want to thank Mike to have added support for the 4 Carpenter Movies ITA edition. 24h support
Thank you very much Mike!!
marcellobuddy
I'm having an issue ripping The Fog using my ASUS BW-16D1HT. Getting constant scsci errors and it often reports, "udf: node fe/efe failed!" I'm usually eventually able to get into the disk, but about halfway through ripping the main title, MakeMKV will gradually begin reading more and more slowly, until eventually coming to a halt and reporting the rip failed.
This is the first time I've attempted to rip a region-locked disk. I've made sure to thoroughly clean the disk, so my hunch is that this might have something to do with the fact that it's region-locked. Either that, or it's a coincidence I suppose. I'm on Mac OS using the latest version of MakeMKV. Drive's firmware is 3.10. Here's some of the errors I've been seeing in better detail:
MakeMKV v1.18.2 darwin(arm64-release) started
Optical drive "BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959' at offset '32372883456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959' at offset '32372946944'
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
File 00008.mpls was added as title #0
File 00007.mpls was added as title #1
Title #00025.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00016.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00026.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00029.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00004.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00003.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00001.m2ts has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00000.m2ts has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00028.m2ts was added as title #2
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959' at offset '32372946944'
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Internal error - Operation was cancelled (140)' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KL8P71D4959' at offset '32768'
keydb_helper
Blu-ray region coding is very distinct from DVD region coding.marcellobuddy wrote: Thu Dec 04, 2025 1:28 pm This is the first time I've attempted to rip a region-locked disk. I've made sure to thoroughly clean the disk, so my hunch is that this might have something to do with the fact that it's region-locked. Either that, or it's a coincidence I suppose.
A DVD drive has a defined region code and this can influence playback of region protected discs, regardless of the (licensed) playback software you might use.
Blu-ray region coding is implemented purely in the software playback solution. Blu-ray drives do not have their own Blu-ray region code. So region coding will only be relevant if you are trying to playback a disc in something like PowerDVD. But when ripping a Blu-ray disc region coding is entirely irrelevant.
For the sake of clarity, a combo Blu-ray/DVD drive will have a region code but it is only relevant for the DVD playback portion. So your Asus BW-16D1HT might have a DVD region code of 1, 2, 4, 5 etc but there is no equivalent hardware region code for Blu-ray regions A, B, and C.
These are just read errors and they did not occur due to any sort of DRM issue. You can try cleaning your disc, using a different drive, or exchanging the disc with your retailer. There isn't really a software solution to your issue.marcellobuddy wrote: Thu Dec 04, 2025 1:28 pm I'm having an issue ripping The Fog using my ASUS BW-16D1HT. Getting constant scsci errors and it often reports, "udf: node fe/efe failed!"
Public KeyDB Disc Submissions
marcellobuddy
Ah gotcha. That’s unfortunate, but I suppose it’s ultimately a coincidence that this is my first region locked disk, and also the only to ever fail in my drive. Felt so randomly connected to me, but a coincidence is a coincidence I suppose. I’ll just have to return the disk.keydb_helper wrote: Thu Dec 04, 2025 2:07 pmBlu-ray region coding is very distinct from DVD region coding.marcellobuddy wrote: Thu Dec 04, 2025 1:28 pm This is the first time I've attempted to rip a region-locked disk. I've made sure to thoroughly clean the disk, so my hunch is that this might have something to do with the fact that it's region-locked. Either that, or it's a coincidence I suppose.
keydb_helper
Out of curiosity, were you having an issue ripping the 4K/UHD Blu-ray of The Fog? Or was it a standard 1080p Blu-ray?marcellobuddy wrote: Fri Dec 05, 2025 12:06 pm Ah gotcha. That’s unfortunate, but I suppose it’s ultimately a coincidence that this is my first region locked disk, and also the only to ever fail in my drive. Felt so randomly connected to me, but a coincidence is a coincidence I suppose. I’ll just have to return the disk.
I ask because I can't seem to see a 4K version of The Fog included in the short list of region locked UHD discs. So in addition to my earlier explanation, it might make things seem a bit less coincidental if the disc wasn't actually region locked.
(If you bought the film in a 2-disc set with both a 1080p and UHD version, any region lock information on the case would almost certainly only apply to the 1080p disc)
