Makemkv Stoppt Blu Ray and UHD
JJ_1966
Post by JJ_1966 »
Hello
i am new here
I ran makemkv several years without problems. But now it stopped working on Blu Rays and UHD. DVD still working.
Also with disk i already has copied.
AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
AACS Ausgabedatei als C:\Users\jensm/.MakeMKV/MKB_v35_Hatari!_DA08.tgz gesichert
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at ug!Y?M}h37%"DxLT:121264257
DEBUG: Code 0 at ug!Y?M}h37%"DxLT:121265890
Das Öffnen der Disk schlug fehl
Can somebody help me? PLEASE!
MakeMKV_log.txt
LoG File
(18.23 KiB) Downloaded 1057 times
Re: Makemkv Stoppt Blu Ray and UHD
Check your MakeMKV directory for a file name that starts with MKB_v66. If you find one, forward it to svq@makemkv.com for analysis.
A new version of AACS has reached stores, and it revokes the key MakeMKV currently uses to open disks. Because it is revoked, the drive will refuse to talk to MakeMKV about ANY BD until a new key is created, which will be part of the next release of MakeMKV.
I've heard stories that restoring the firmware to a state prior to the insertion of the "bad disk" can fix this, but I have not seen confirmation of that. It would be an interesting experiment if someone could try it in a controlled environment... I don't have a v66 disk, nor do I have a drive that was flashed.
iMactouch
Post by iMactouch »
I tried another program for my Mac to rip Bluray and this is normally working. But Makemkv is not longer working.
iMactouch
Post by iMactouch »
Woodstock wrote:
Sun Nov 04, 2018 5:22 pm
If you read the message before you will see this:
"AACS Ausgabedatei als C:\Users\jensm/.MakeMKV/MKB_v35_Hatari!_DA08.tgz gesichert"
So the Bluray uses AACS v35 and not v66, but Makemkv is not working.
JJ_1966
Post by JJ_1966 »
Yes this is a old disk.
I have already ripped on hard disk some month ago.
I changed nothing on the System.
You do not have to rip a disk with a "revoking" AACS version to have it break ripping - it merely has to be inserted while the drive is powered up. When the drive spins up the disk and starts reading it, it finds the revocation information and updates its firmware, all without sending a bit to the computer.
JJ_1966
Post by JJ_1966 »
I have already tried to reprogramm the firmware on the drive.
No changes.
iMactouch
Post by iMactouch »
Interestingly I used to rip the not working Bluray with the testversion of DVDFab and there it is ripping without any problems.
But Makemkv is not able to rip another, older Bluray.
JJ_1966
Post by JJ_1966 »
I saw in the .Makemkv folder that
i also tried to ripp this disc.
AACS Ausgabedatei als C:\Users\jensm/.MakeMKV/MKB_v66_Warriors_4750.tgz gesichert
That has v66 on it. I cant say was it bevor the error or not. Because i installed makemkv new.
I hope that helps
Send the file C:\Users\jensm\.MakeMKV\MKB_v66_Warriors_4750.tgz to support@makemkv.com for analysis.
This will require a new version of MakeMKV to fix.
JJ_1966
Post by JJ_1966 »
Hello here ist the file.
(50.86 KiB) Downloaded 1032 times
Post by d00zah »
JJ_1966 wrote:
Tue Nov 06, 2018 4:55 pm
MakeMKV v1.14.0 released. Should fix the cert revocation problem.
iMactouch
Post by iMactouch »
Yes, it does!
JJ_1966
Post by JJ_1966 »
Super everything
works again with the new version.
Thank you !!!!
Frank_Kulik
Post by Frank_Kulik »
Same with me, now:
No blu-ray or uhd works anymore. DVDs still work. They all fail with "cannot open disc". It's one with v62 and ones with v66 codec.
I have installed the newest makemkv version and already re-installed it. My program is on drive E, the .makemkv-file is on drive C - so not in the same folder.
Nothing has changed on my pc system.
I also tried a disc that went through successfully two weeks ago. Also this one does not work anymore. MAKEMKV keeps trying to read it and ultimately fails after some five minutes saying: "Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:29396115
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:213134262"
I have attached the tgz file of the one i had already successfully done 14 days ago which also doesn't work anymore. Maybe you can try to help me ...?
MKB_v66_The_Unthinkable_6248.tgz
(104.53 KiB) Downloaded 924 times
Locked
