Locked
@LoSLucifer
Yeah, the steps can seem a bit daunting but really, this is the easy part!
Anyway, I have created a 3.02 for you. Just unzip it and you are good to go. Yes, use the same program (dosflash) to erase the firmware and then install the new firmware.
Let us know how you went..
LoSLucifer-ASUS-BW-16D1HT 3.02-TEST.bin.zip
(1.29 MiB) Downloaded 527 times
LoSLucifer
Post by LoSLucifer »
@MartyMcNuts
Many thanks for your help. Will keep you updated.
:D downloading the patched file now.
LoSLucifer
@MartyMcNuts
Just love it! Works like a charm! Fw 3.02 is uploaded.
Finaly i can make backups and play them on my shield in my homecinema <3 Will buy this program for shure! Thanks to all who has figured this fix out.
Place out from Norway.
@LoSLucifer
Your welcome! Have fun backing up your movies!!
nixxes
Post by nixxes »
Hi
I have followed the steps in Post 1 using the Windows method. I had 3.03 firmware and modded 3.01 in a hex editor with the data from my dump. However this seemed to kill the drive, so I presume I edited it wrong! I have managed to load the original dump back on so the drive is working again just not reading UHD discs. Is anybody able to please edit my dump for me as this is the limit of my knowledge! I have attached it, changing the ext to .txt so I could upload it.
Any help would be greatly appreciated.
303 Dump.bin.txt
(2 MiB) Downloaded 466 times
Post by d00zah »
Follow the steps in 1st post section 'Steps for importing data from backup firmwares : (Automatic Method)'.
The EEPOM Data Mover will do the cal data merge automatically.
@nixxes,
Here you go. Firmware ASUS 3.02 created using your dump and the EEPROM Data Mover. Install this and you should be good to go.
nixxes-ASUS-BW-16D1HT-3.02-test.bin.zip
(1.29 MiB) Downloaded 638 times
OptimalSpeed
Post by OptimalSpeed »
Hello all, I am new here and have recently built a NAS server & want to rip all my movies including 4K. I recently purchased a Asus BW-16D1HT because I heard it was able to RIP 4K DVDs however the latest firmware apparently has nixed this idea. I have come upon MakeMKV while looking into how to get this to work. I have dumped the firmware 3.03 and was wondering if someone here could help me with downgrading it to a version that will help me accomplish my mission. Thanks for any help in this matter :)
AsusFirm3.03.zip
(1.3 MiB) Downloaded 498 times
hayeledd
Post by hayeledd »
hello TeddyRaspin
I have performed the dump firmware using DOS Method, which it was a success. I also save and zipped it as you recommend it. Where should I send you this file?
Emy78
Post by Emy78 »
Does anyone have any suggestion on how to downgrade the firmware of the Asus on a laptop, please?
It can't be possible that there's no way to downgrade the firmware using an USB 3.0 port.
@OptimalSpeed
Here is a 3.02 for you using your data dump. Let us know how you go.
OptimalSpeed-ASUS-BW-16D1HT_3.02-test.bin.zip
nixxes
Post by nixxes »
@MartyMcNuts
Thank you so much for the update 3.02 Firmware. It worked perfectly!
@nixxes
Your very welcome. Have fun backing up your UHD's!!!
Colindo
Post by Colindo »
Hi everyone,
I also have the Asus BW-16D1HT and Firmware 3.03. I used the DOS-method to read my firmware, however it keeps saying "Unknown flash chip" after I type R and press enter. Until that point, everything works. The drive is also in IDE mode on an old motherboard.
Any idea what I can do? Does it work better with the Windows 7 PE?
Post by d00zah »
Colindo wrote:
Sun Nov 11, 2018 7:17 pm
Hi everyone,
IIRC, when following the same DOS procedure, step 5:
At the command Prompt, type "DOSFLASH" and press Enter. If it does not detect anything, retype again. It could be needed to type DOSFLASH 3-4 times before ASUS/LG device be properly detected. It should show the Manufacter ID of your device, namely "MediaTek MT1959".
Was, more often than not, the case. However, once properly detected, everything went as described.
Locked
