Error reading 1 of the titles
bedwyr
#1 Post by bedwyr » Tue Nov 06, 2018 3:21 am
I am having a problem with a single title on one disk. Its Ben 10 Season 2 Disk 1. I've been able to use other seasons and even season 2 disk 2. I get a 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' and after some searching most people said that error is from a dirty disk. Cleaned the disk no luck. Sent it back and got another still no luck. Now I'm on the third disk and the error is the same but just for that one title.
Here is the output of the debug:
Debug log started at Tue Nov 06 03:07:54 2018 , written by MakeMKV v1.12.3 win(x64-release)
001005:0000 MakeMKV v1.12.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
001003:0020 DEBUG: Code 101019395 at =4zbW"fS5%Mt|jza:121269823
001003:0020 DEBUG: Code 101019395 at /SJoTo5:0-tm*WgK=z:213131686
001003:0020 DEBUG: Code 101019395 at /SJoTo5:0-tm*WgK=z:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE  WH16NS40 1.03' at offset '1048576'
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003019:0000 Cells 41-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (40 cell(s), 3:03:07)
Title skip vts=1 pgcn=1 hash=E0E98E58495143EF
003019:0000 Cells 6-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (5 cell(s), 0:22:58)
Title skip vts=1 pgcn=2 hash=7A64C9985020F5DA
003028:0000 Title #3 was added (5 cell(s), 0:22:57)
Title skip vts=1 pgcn=3 hash=EBA5D7097CE89FF1
003028:0000 Title #4 was added (5 cell(s), 0:22:52)
Title skip vts=1 pgcn=4 hash=45338909B83477E7
003028:0000 Title #5 was added (5 cell(s), 0:22:32)
Title skip vts=1 pgcn=5 hash=BA9DF5952795493A
003028:0000 Title #6 was added (5 cell(s), 0:22:56)
Title skip vts=1 pgcn=6 hash=F5366BDE783D197B
003028:0000 Title #7 was added (5 cell(s), 0:22:57)
Title skip vts=1 pgcn=7 hash=77305CE179842DFC
003028:0000 Title #8 was added (5 cell(s), 0:22:59)
Title skip vts=1 pgcn=8 hash=CE4B77B872A82A7E
003028:0000 Title #9 was added (5 cell(s), 0:22:56)
Title skip vts=1 pgcn=9 hash=2A1F5D90EEA9C7D9
003025:0000 Title #10 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #16 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/DVD RIPS/BEN_10_SEASON_2_DISC_1
001003:0020 DEBUG: Code 0 at [9CTUcW}lT(|/'*^W:121262026
004007:0010 AV synchronization issues were found in file 'D:/DVD RIPS/BEN_10_SEASON_2_DISC_1/BEN_10_SEASON_2_DISC_1_t04.mkv' (title #5)
004008:0010 AV sync issue in stream 1 at 0:02:37.312 with duration of 32ms : broken timecode, apparent audio skew is -157.312s
004047:0010 AV sync issue in stream 0 at 0:02:37.323 : video frame timecode differs by -157.323s
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 4 to file D:/DVD RIPS/BEN_10_SEASON_2_DISC_1/BEN_10_SEASON_2_DISC_1_t04.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Nov 06 03:10:02 2018
I hope someone can help with this issue. I was even looking at buying a better drive but didn't see any that might be newer or better.
Thanks in advance.
Re: Error reading 1 of the titles
#2 Post by Woodstock » Tue Nov 06, 2018 2:34 pm
First try it with version 1.12.2, as .3 has issues with some subtitles.
https://makemkv.com/download/old/
There is additional information on WHY to try .2 here: https://makemkv.com/forum/viewtopic.php?f=1&t=17872
bedwyr
#3 Post by bedwyr » Tue Nov 06, 2018 4:41 pm
Thanks for the reply Woodstock, unfortunately reverting to 1.12.2 was one of the first things I tried as I had just upgraded prior to using that disk. I should have mentioned that in my original post.
bedwyr
#4 Post by bedwyr » Fri Nov 09, 2018 2:47 pm
Here is an updated debug based on makemkv 1.14.1. Its strange its just title 4. The rest of the titles all read correctly. This is the 3rd replacement of the same disk. Any idea what the debug codes mean?
MakeMKV v1.14.1 win(x64-release) started
DEBUG: Code 101019395 at eJ[G2qt+,=.<H`5ee>:213131548
DEBUG: Code 101019395 at eJ[G2qt+,=.<H`5ee>:121261934
Saving 1 titles into directory D:/DVD RIPS/BEN 10 SEASON 2 DISC 1
DEBUG: Code 0 at WS|VAXH*QJ.l{.H6}:121262026
DEBUG: Code 4294957866 at p:P[,:]b2AVs'dl]gLz(:29406189
DEBUG: Code 0 at p:P[,:]b2AVs'dl]gLz(:213139897
DEBUG: Code 0 at W*(LwO(hz3aLoK(1eiSa :213136608
DEBUG: Code 1 at G@lqFngCk[J78,_e:29395195
DEBUG: Code 0 at G@lqFngCk[J78,_e:29397058
DEBUG: Code 0 at L[k>dhTI5_@{<5+sOE>p:29393286
Failed to save title 4 to file D:/DVD RIPS/BEN 10 SEASON 2 DISC 1/BEN 10 SEASON 2 DISC 1_t04.mkv
