Johnny English Reborn
tinyt1553
#1 Post by tinyt1553 » Mon Nov 05, 2018 2:25 am
Mac OSX Mojave, trying to rip Johnny Enlgish reborn and getting read error. Disc is clean and plays fine in blu ray player.
Do I need the hashed key for it?
Anyone else run into this with this disc?
Several other movies have ripped fine since mojave update.
Re: Johnny English Reborn
#2 Post by Woodstock » Mon Nov 05, 2018 3:34 pm
There are dozens of different "read errors". Need to know which you're receiving (preferably from a Debug log, which has more detail) to make guesses.
tinyt1553
#3 Post by tinyt1553 » Tue Nov 06, 2018 12:54 am
@woodstock here's the output from the conversion screen and blow that is the output of the log.
MakeMKV v1.12.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/admin/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.01d" opened in OS access mode.
Backing up disc into folder "/Users/tomthompson/Desktop/backup/J_ENGLISH_REBORN_NA"
File "/123124576.zip" was skipped
File "/FilmIndex.xml" was skipped
DEBUG: Code 0 at -hZ0_.kYU59.:JV+=:213135481
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50299.m2ts' at offset '66699264'
DEBUG: Code 0 at K"bG+2THYoFa3gj|%MT:29397679
DEBUG: Code 0 at K"bG+2THYoFa3gj|%MT:121265131
DEBUG: Code 0 at k[BpjPm&i#].;}zJct9A:29396713
Encountered 12 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
Output from LOG:
Debug log started at Tue Nov 6 00:46:57 2018 , written by MakeMKV v1.12.3 darwin(x64-release)
001005:0000 MakeMKV v1.12.3 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/admin/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.01d" opened in OS access mode.
005072:0000 Backing up disc into folder "/Users/tomthompson/Desktop/backup/J_ENGLISH_REBORN_NA"
DEBUG: Code 2365587456 at f=Xy"e"yY$f/\gZd:29405660
DEBUG: Code 0 at f=Xy"e"yY$f/\gZd:213139943
DEBUG: Code 0 at ,,F[\O1Kvxjn[m=c:29400623
DEBUG: Code 2147483648 at f=Xy"e"yY$f/\gZd:213133250
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=KaQ62u2QUX9dE1VtCexfxjdA8A0a7emkezPOS4z1bUafLcdzYifiNhfFFhH27O4+nM8GIY1zadFDgLVzryUIwG98aAdPWrpa9lvjUFULpMfhQoshU3O2JngM9gykm9Y5mUT4+YwJELH/IQgxQRd4OF8lunNoVJTlqw==
DCE=Uk2e5KitTUE8ooS3Jih51VxL/oyvxID+T2bfaxgrq5ueh1pFlE9v7N11c1SIHjfgrh6AtsWyA7C6FH5l+0W5a3Iv2PZVWXDnbajsljSJcikPJHJRMskR4ZsYONE1kwxM5iTZ83YKigHkK32G/n/eq7U57mOwoNSHVQ==
005094:0000 File "/123124576.zip" was skipped
005094:0000 File "/FilmIndex.xml" was skipped
001003:0020 DEBUG: Code 1073741829 at Jbfr])KLDdW<4rRa:29393953
001003:0020 DEBUG: Code 0 at -hZ0_.kYU59.:JV+=:213135481
001003:0020 DEBUG: Code 100864261 at 8#L6D"D`=7;p&.e`:121269823
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/50299.m2ts' at offset '66699264'
001003:0020 DEBUG: Code 0 at K"bG+2THYoFa3gj|%MT:29397679
001003:0020 DEBUG: Code 0 at K"bG+2THYoFa3gj|%MT:121265131
001003:0020 DEBUG: Code 0 at k[BpjPm&i#].;}zJct9A:29396713
002023:0000 Encountered 12 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=12 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
005069:0080 Backup failed
005080:0204 Backup failed.
#4 Post by Woodstock » Tue Nov 06, 2018 2:11 am
First suspicion would be the power to the drive. I have one of these, and they work well for ripping, so long as they get "full" USB power. If they don't (plugged into a hub that doesn't have its own power supply, or a laptop on battery), they can go off-line at top speed.
HOWEVER.... Given that on two runs it hit an error at the SAME offset (66699264) in the SAME file (50299.m2ts), more likely is a bad spot on the disk itself.
If you use Open/Save as MKV instead of backup, do you also get an error at that location?
tinyt1553
#5 Post by tinyt1553 » Thu Nov 08, 2018 3:03 am
The drive is plugged into a powered USB hub so power is not the issue. It ended up being a bad disc. THANK YOU for your help
