Someone on these forums had success with a WH14NS40 and FW 1.02. There may be more than one version of that drive around. I was not able to read UHD discs with the WH14NS40 in this system. Symptom is "no disc" in either Windows or MakeMKV. Tested FW 1.01, 1.02 and then, since it wasn't working anyway, 1.03 (just for Windows). No go with any of these.
Time for a new drive.
WH14NS40 - nope
Re: WH14NS40 - nope
If the SVC code on the label does not say "NS50" or higher, it won't work - the hardware doesn't support BD-XL reading well enough to do UHD, and no change in firmware will make it work.
jonghotti
Re: WH14NS40 - nope
I've got it ready to go for you.yorick wrote: Sun Nov 04, 2018 4:15 pm Someone on these forums had success with a WH14NS40 and FW 1.02. There may be more than one version of that drive around. I was not able to read UHD discs with the WH14NS40 in this system. Symptom is "no disc" in either Windows or MakeMKV. Tested FW 1.01, 1.02 and then, since it wasn't working anyway, 1.03 (just for Windows). No go with any of these.
alexcoluzzi32@gmail.com
