Can't rip Blu Rays
phngyn
Can't rip Blu Rays
Post by phngyn »
Hello, so I've been using MakeMKV for awhile and I decided to purchase it today. However, when I tried to rip a blu ray the following shows up (I cut it down to shorten it):
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:daa64f7d184c1384:HL-DT-ST DVDRWBD CT10N A103'
I'm on the latest version v1.12.3 and this hasn't happened before. I tried to go back to a previous Blu Ray that I had already ripped and then the same message showed up, but before I ripped it with no problem. I also tried to rip regular DVDs and that ripped with no problem as well. I've tried to read around the forum, but from what I understood I might have to wait until a new version comes out? I wanted to ask just to make sure though. Thanks :)
Re: Can't rip Blu Rays
AACS version 66 has hit the streets, and it appears to be a "revoking" version - revoking the decryption key MakeMKV uses. Because of that, MakeMKV will be unable to rip any BDs until Mike releases a newer version that has a new key.
To help speed this process, check your MakeMKV data directory for a file that has a name beginning with "MKB_v66_" and send it to svq@makemkv.com for analysis.
phngyn
Post by phngyn »
Thanks for the reply. Just noticed after making this post that it was AACS v66 and the latest MakeMKV is v65. Hopefully the new version comes out soon, sucks that I purchased it and now I can't rip blu ray. Nobody's fault but mine though lol
Post by d00zah »
phngyn wrote: Fri Nov 02, 2018 9:37 pm Thanks for the reply. Just noticed after making this post that it was AACS v66 and the latest MakeMKV is v65. Hopefully the new version comes out soon, sucks that I purchased it and now I can't rip blu ray. Nobody's fault but mine though lol
MakeMKV v1.14.0 released. Should fix the cert revocation problem.
phngyn
Post by phngyn »
d00zah wrote: Tue Nov 06, 2018 10:26 pm
Yess!!! Thank you so much for letting me know, the problem is fixed and the BD is now ripped! Thank you and to MakeMKV :)
