Dracula Untold
ESPNY
Dracula Untold
#1 Post by ESPNY » Thu Nov 01, 2018 6:35 pm
I own the European version of Dracula Untold and I cannot create an ISO/folder backup since none of the hashkeys are working. Have been waiting for almost one year by now but it was not provided yet. How could get the appropriate key? (Italian Version)
Thanks for any help appreciated!
Re: Dracula Untold
#2 Post by d00zah » Thu Nov 01, 2018 6:57 pm
Have you submitted a dump? See the 'Hashed Keys/How do I discover the key for a disc I have?' section:
viewtopic.php?f=12&t=16883
ESPNY
Re: Dracula Untold
#3 Post by ESPNY » Thu Nov 01, 2018 7:31 pm
Thank you!
gonca
Re: Dracula Untold
#4 Post by gonca » Thu Nov 01, 2018 9:26 pm
cannot create an ISO backup
I might be wrong but MakeMKV might not be able to produce ISO backups, but it can do folder structure
st4evr
Re: Dracula Untold
#5 Post by st4evr » Thu Nov 01, 2018 9:30 pm
That is correct. MakeMKV does NOT create ISO file backups. Only full folder structure backups.
A separate app can be used to create the ISO from the folder structure backup if needed.
Re: Dracula Untold
#6 Post by d00zah » Thu Nov 01, 2018 9:48 pm
I caught that before responding, but chose to interpret it as a typo, or an allusion to a UHD key 'drama' that played out on a different forum. Either way, submitting the dump is 'phase 1'.
ESPNY
Re: Dracula Untold
#7 Post by ESPNY » Sun Nov 04, 2018 6:39 pm
Yes, I meant full folders. I did send the dump file. How long would it take to receive a key normally ?
Re: Dracula Untold
#8 Post by Woodstock » Sun Nov 04, 2018 6:47 pm
If you're using v1.12.3, the newest keys are automatically downloaded when you select "Open" or "backup", after you start the program. Versions prior to 1.12.3 require a manual download, and the manual download isn't updated quite as often.
