I've just bought an Asus with a OWC Mercury Pro enclosure. I need a longer USB cable for it but not sure which is the correct one, the box says it's a USB 3.1
This looks similar but the holes in the upper part of the B end look slight different
https://www.amazon.co.uk/AmazonBasics-U ... B00NH144GK
Has anybody bought a longer cable for their OWC Mercury Pro?
OWC Mercury Pro USB cable
Re: OWC Mercury Pro USB cable
That is the correct cable it's a standard USB 3.0 A to USB 3.0 B
Great, thanks
