Cannot read some discs
Rainer
#1 Post by Rainer » Tue Oct 30, 2018 7:31 pm
I have a Asus BW-16D1HT and no stand-alone-player (so I cannot verify whether something is wrong with the not working discs).
The Asus is connected via SATA-USB-Adapter.
The drive works with some discs.
I was able to copy the UHD Kong: Skull Island & Atomic Blonde.
But with 2 other UHD I have the problem that the drive (windows) don't recognise them.
I mean that the OS doesn't show me that a disc is in the drive.
The Asus is spinning again and again.
The discs are Independent Day & Miss Peregrine's Home for Peculiar Children.
The drive seems to be okay since it recognises still the first two discs.
What could be the reason?
I am using Windows 8.1 but it doesn't seem to be an OS problem (tried to connect the drive to Win 7)
The drive was manufactured in January 2018.
MakeMKV shows
Revision: 3.02
Firmware date: 2117-11-24
Re: Cannot read some discs
#2 Post by Woodstock » Tue Oct 30, 2018 9:27 pm
What version of MakeMKV are you using?
rivey
#3 Post by rivey » Wed Oct 31, 2018 1:04 am
Also, I am assuming that the discs are all new since you don't have a stand alone player. Woodstocks question is something that we need to know. My question is this. Have you cleaned the discs? I recommend doing that for all discs. The best way to do it is to us a 50/50 mix of distilled water and rubbing alcohol with a clean microfiber cloth. Good Luck.
Rainer
#4 Post by Rainer » Wed Oct 31, 2018 6:14 am
I tried to clean the discs before - with no luck.
I use MakeMKV v1.12.3 win (x64 release).
But shouldn't the file manager of windows show the files of the discs - regardless of the version of MakeMKV?
Or are some discs always being 'hidden'?
rivey
#5 Post by rivey » Wed Oct 31, 2018 4:32 pm
There is a documented problem with v1.12.3. You should go back and install v1.12.2 and your problem should go away.
Rainer
#6 Post by Rainer » Wed Oct 31, 2018 10:07 pm
I don't find an official download link for version 1.12.2 :-(
#7 Post by Woodstock » Thu Nov 01, 2018 2:11 am
In the message (currently) at the top of the General section on 1.12.3, the link to old versions is:
https://makemkv.com/download/old/
Rainer
#8 Post by Rainer » Thu Nov 01, 2018 10:25 am
I tried
https://www.makemkv.com/download/
and
https://www.makemkv.com/download/Setup_ ... 1.12.2.exe
and couldn't find the old versions.
Edit:
Version 1.12.2 showed the disc but I got the following errors
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '32494647296'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '32494647296'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00605.m2ts' at offset '129024
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '32494647296'
So I have to assume that the disc is damaged?
Or could the drive have problems?
Rainer
#9 Post by Rainer » Thu Nov 01, 2018 12:11 pm
It seems to be the disc.
After trying several times the drive became very warm.
And when I ejected the disc now - it had a crack.
