The Spy Who Dumped Me (US Retail)
Here's what I got. Chime in if it's not what you got.
Title information
Name: The Spy Who Dumped Me (English)
Source file name: 00691.mpls
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Segment map: 513,518,501,505,515,519,504,509,508,506,510,517,514,511
File name: The_Spy_Who_Dumped_Me_t162.mkv
Title information
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Re: The Spy Who Dumped Me (US Retail)
691 doesn't exist on the rental. Anyone want to take a stab at the RB version?
Edit: I got 892.mpls for RB edition.
Edit 2: Watched it and 892.mpls is indeed correct for the RB edition.
It is nether 00691.mpls or t162.mkv on a Redbox
I too need the correct mpls for the Red Box version. Any help is appreciated.
Ok I just saw 0892. I'll give it a try. Thanks
Where did you find 892 or 691? Mine:
892:
Title information
Source file name: 00892.mpls
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Segment map: 514,505,507,506,518,519,504,508,511,502,513,515,509,503
File name: The_Spy_Who_Dumped_Me_t214.mkv
691:
Title information
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Segment map: 514,505,507,506,518,519,509,513,515,508,504,502,511,503
File name: The_Spy_Who_Dumped_Me_t177.mkv
892:
Title information
Duration: 1:56:56
Chapters count: 16
Segment count: 14
691:
Title information
Duration: 1:56:56
Chapters count: 16
Segment count: 14
I have both 691 and 892 but the segment maps do not line up even close with what is displayed here?
Any help would be appreciated
I have a ton of them as well. Need to know which is main.
Been away from ripping for a couple years with a few moves and job changes. Just set up a plex server. Have a new PC so no longer have Blu-ray software to watch on my PC. So I can't check playlist like I used to. Prefer not to have to buy software that I will never use. This could still work if someone could try??? Used to use Resource monitor available via TechNet and set a filer to show only mpls files. Then once the main movie starts I capture what mpls file comes up in RM. Worked great. Unless things have changed since then...
It looks like 00892.mpls is the winner. Don't let the birthday party flashbacks through you off like it's a misaligned segment its just a weird way they edited the film.
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Duration: 1:56:56
Chapters count: 16
Segment count: 14
How did you determine that? Just curious. Seems to be several versions of this disc.
Just wanted to confirm. I ripped it today and 00892.mpls is the correct one. Watched it to make sure and the movie runs in the correct order.
Duration: 1:56:56
Chapters count: 16
Segment count: 14
This is for the rental version only.
Duration: 1:56:56
Chapters count: 16
Segment count: 14
For the NF rental, I tried both 691 and 892 the "old fashioned" way by playing both files while watching the disc in my BR player. The disc chapters matched up with the 892 map - 514,505,507,506,518,519,504,508,511,502,513,515,509,503.
Just joined to inquire more on the particular title. On my disc, closest mpls is 00881 then jumps to 00903. And practically none of the segments on this disc come close to the reported 892.
Majority of segments starts: 513,518,501,505,515,510,504,514,517,509,519,508,506,511
File name: The Spy Who Dumped Me_t210.mkv
Even the .mkv file that is named identically to 892 does not resemble on post. Here's mine with 00915, but has the same t214.mkv:
Source file name: 00915.mpls
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Segment map: 513,518,501,505,515,517,519,510,508,506,509,514,504,511
File name: The Spy Who Dumped Me_t214.mkv
I'm at a lost as to which one to choose, any one else care to chime in?
Duration: 1:56:56
Chapters count: 16
Segment count: 14
Well I Don't Know
I might be late to the party, but for future:
I was in same situation as fccn75.
What helped:
A Better Way To Find The Correct Playlist/Segment Map
https://www.makemkv.com/forum/viewtopic.php?t=16251
I used trial version of Cyber Link PowerDVD 18
It takes a bit of time, but this method pointed me to the right .mpls to select.
In this case it was 00691.mpls
Segments: 513,518,501,505,515,519,504,509,508,506,510,517,514,511
I hope this helps at least someone
And thank you to everyone for making this possible!
What helped:
