Weird image artefacts ripping CTHD
immoenis
Post by immoenis » Sat Oct 27, 2018 8:07 pm
Using all default settings, havent touched a thing in the settings etc. Never had an issue like this one with MakeMKV before and I ve ripped my whole dvd/bluray collection up until this disc.
Drive Information:
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: K9AI1FA4942
Firmware date: 2117-11-15 17:16:
Bus encryption flags: 1F
Highest AACS version: 63
Disc Information:
Label: DVDVolume
Timestamp: 2036-02-07 06:28:15
Data capacity: 7.75 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Disc open log:
MakeMKV v1.12.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\***/MakeMKV_log.txt
Title #1 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 1 cells and 1594 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #2 was added (1 cell(s), 0:13:49)
Complex multiplex encountered - 1 cells and 2624 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #3 was added (1 cell(s), 0:22:44)
Title #4 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 1 cells and 774 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #8 was added (1 cell(s), 0:06:42)
Title #9 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 19 cells and 13308 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #10 was added (19 cell(s), 1:55:12)
Title #11 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
This is what it spits out now ...
https://imagebin.ca/v/4KZaZ10PrmmY
https://imagebin.ca/v/4KZai4NEd9cB
https://imagebin.ca/v/4KZaowEtHRP9
https://imagebin.ca/v/4KZaus231XgJ
https://imagebin.ca/v/4KZdrWBFpkb7
Re: Weird image artefacts ripping CTHD
Post by Woodstock » Sun Oct 28, 2018 2:23 am
What are you playing the MKV with? The images look like what you get when you play a VC1-Interlaced video on a player that doesn't "do" VC1i, but that should not happen on a DVD source (VC1i is BD only, as far as I know).
immoenis
Post by immoenis » Tue Oct 30, 2018 4:49 pm
Latest VLC as well as MPC-BE. Same result in both players. Also, playing/opening the DVD directly in either of the players renders the same result.
