no specific error - just shutdown on fatal error about 1/3 into first title00 extraction
running OSX latest - MKV latest
here is log report
Debug log started at Wed Jul 21 17:59:32 2010 , written by MakeMKV v1.5.7 beta darwin(x86-release)
001005:0000 MakeMKV v1.5.7 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/KenHome/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BH10LS30 1.00" opened in OS access mode.
DISCID=4B4BC1335360A1B0E17CE720F2D5848822A1FB31
003025:0000 Title #00005.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00400.mpls was added as title #0
003307:0000 File 00006.mpls was added as title #1
003307:0000 File 00014.mpls was added as title #2
003307:0000 File 00030.mpls was added as title #3
003309:0000 Title 00050.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00051.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00052.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00053.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00054.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00055.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00056.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00057.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00058.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00059.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00060.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00061.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00062.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00063.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00064.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00065.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00066.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00067.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00068.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00069.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00070.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00080.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00000.mpls is equal to title 00400.mpls and was skipped
003309:0000 Title 00504.mpls is equal to title 00400.mpls and was skipped
003025:0000 Title #00002.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00220.m2ts was added as title #4
003307:0000 File 00222.m2ts was added as title #5
003307:0000 File 00269.m2ts was added as title #6
003025:0000 Title #00285.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00286.m2ts was added as title #7
003307:0000 File 00287.m2ts was added as title #8
003307:0000 File 00288.m2ts was added as title #9
003307:0000 File 00289.m2ts was added as title #10
003307:0000 File 00290.m2ts was added as title #11
003025:0000 Title #00291.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00297.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 12 titles into directory /Users/KenHome/Desktop/Ripped BDs/Mamma Mia!
001003:0020 DEBUG: Code 0 at b'Bp}f~~`"lC5mO"h+COx:29393976
001003:0020 DEBUG: Code 0 at b'Bp}f~~`"lC5mO"h+COx:121263084
001003:0020 DEBUG: Code 0 at UC;,-O4CK-E0_(P6d &a:29396184
001003:0020 DEBUG: Code 0 at b'Bp}f~~`"lC5mO"h+COx:29395195
002003:0000 Error 'Internal error - Decryption error (411)' occured while reading '/BDMV/STREAM/00220.m2ts' at offset '9548402688'
001003:0020 DEBUG: Code 0 at -|v4V[?/0XmKJ?[!:213136769
001003:0020 DEBUG: Code 117834139 at eWNAnDZ;jW\R*85wZ):213132422
001003:0020 DEBUG: Code 117834139 at eWNAnDZ;jW\R*85wZ):29393654
001003:0020 DEBUG: Code 0 at TWRDDd+0V\.}k9\)E43_:213130628
001003:0020 DEBUG: Code 0 at %PXvuT~Sn/.}L41h:'c[:213129823
001003:0020 DEBUG: Code 0 at TWRDDd+0V\.}k9\)E43_:213130513
001003:0020 DEBUG: Code 4662306 at TWRDDd+0V\.}k9\)E43_:213129639
mamma mia blu-ray crashes
- Contact:
Re: mamma mia blu-ray crashes
This error happens when data read from the drive is garbage, and that in turn happens when reading scratched disc on some drives. Please try to clean disc gently.
yep - that was the problem;
Had some significant smudging; Some gentle soap and water and works like a charm...
I'll look for that first from now on
thanks Mike...
thanks Mike...
- Contact:
Glad it worked. For reference, what kind of blu-ray drive do you have? Normally drive should have returned a clear error message rather then silently produce garbage,
