Issues with Kill Bill Vol 1 & 2 Blurays
mostlyhuman
Post by mostlyhuman » Fri Jul 03, 2009 3:03 am
I am ripping these to the hard drive first with AnyDVD then MakeMKV will hang when opening the files. It will load some of them and then just stop. Its happening with both Kill Bill 1 & 2 and are the only disks I am having problems with. Anyone else experiencing or aware of this issue?
NomadCF
Re: Issues with Kill Bill Vol 1 & 2 Blurays
Post by NomadCF » Fri Jul 03, 2009 6:22 pm
While not with either of my DVDs of Kill Bill (just re-ripped them to make sure). I do have this issue with all of my Blurays of Pirates of the caribbean. In the end I just used used tsMuxeR to rip those to M2TS files. as MakeMKV would just lock up on those (and only those so far) blurays.
Side note: Heres how I rip a Bluray
1. Create a complete copy of the Bluray to my external drive (I was doing this straight to my mediacenters Hardrives but due to the shear volume of straight data I was getting network overruns and errors. I have since fixed this issue using 2 bonded gigabit network cards in the mediacenter).
Heres my little script simplified (redhat/centos/yellowdog compat)
screen
/sbin/mount.ntfs /dev/sdd2 /media/usb
dd bs=128k if=/dev/cdrom of="/media/usb/Bluray_Title.iso"
sync
sync
sync
eject
cd /
umount /media/usb
2. I then plug the usb drive into the mediacenter, and mount the ISO using Virtual CloneDrive : http://www.slysoft.com/en/virtual-clonedrive.html
3. Make sure AnyDVD HD is active for that drive : http://www.slysoft.com/en/anydvdhd.html
4. Rip Blueray with MakeMKV
steve.walton
Post by steve.walton » Mon Jul 13, 2009 5:43 am
i can confirm this, Killbill 1 + 2 will not even get through reading the titles. Disk continues to spin for hours reading title 0:0 on both disks
Ive used AnyDVDHD to rip the disks to ISO's ( removing encryption ) but makemkv still will not read the titles. If i can be of any help just sing out.
Steve :?:
Post by mike admin » Wed Jul 15, 2009 7:25 am
The next version will not contain fix for this, but it will contain better error reporting that will help us to find the cause. There is nothing that can be done for now, unfortunately.
steve.walton
Post by steve.walton » Mon Jul 20, 2009 3:49 am
installed new version, was i supposed to uninstall the previous version somehow?
is there supposed to be a log file somewhere?
anyway here is a screenshot running against my ripped iso, hope it helps but the log looks sparse.
Makemkv becomes unresponsive and needs to be forced to quit - same with disk rip version
running on Linux Mint 7
steve
WolfOfCampscapel
Post by WolfOfCampscapel » Tue Jul 21, 2009 2:32 pm
Same here.
The UK Kill Bill bluray I have here have an "interesting" H.264 stream without a fps field, so mplayer won't show any video without "-fps 23.976" added to its options.
And the DTS/AC3 sound tracks are german/french/etc, not english. Looks like there's only one english sound track, and that's in LPCM format.
Ah well, looks like a run through tsmuxer and friends can fix things up.
Post by mike admin » Mon Aug 03, 2009 10:34 am
1.4.6 should open thses just fine. Please try it and post results.
steve.walton
Post by steve.walton » Tue Aug 04, 2009 3:03 am
cant compile oss package
libmakemkv/src/world.cpp: In member function ‘virtual uint8_t CDefaultWorld::random_byte()’:
libmakemkv/src/world.cpp:77: error: ‘rand’ was not declared in this scope
make: *** [out/libmakemkv.so.1.full] Error 1
on Linux Mint 7
steve
steve.walton
Post by steve.walton » Tue Aug 04, 2009 1:21 pm
OK, after fixing the compile problem, makemkv works well
KillBill Vol 1 works - no probs
KillBill Vol 2 Fails and here is the log file
Debug log started at Tue Aug 4 13:08:43 2009 , written by MakeMKV v1.4.6 beta linux(x64-release)
001014:000000:0000 MakeMKV v1.4.6 beta linux(x64-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /home/steve/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00011
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00008
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00012
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00015
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00002
003313:000000:0000 File 00001.mpls was added as title #0
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00006
003020:000000:0000 Title #00005.mpls has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00013
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00014
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00003
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00007
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00004
003020:000000:0000 Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00004.m2ts was added as title #1
003020:000000:0000 Title #00007.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00009.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00010.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00002.m2ts was added as title #2
003313:000000:0000 File 00005.m2ts was added as title #3
003020:000000:0000 Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00008.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /home/steve/Videos/KILLBILL2_GBR
tp=P8QLwpP0X9AIAAfyu8kPu8fsu9FAAAPgN81brUvlO9NoAAPPd83Loe/hA9Q3///GK8mrlL/k39C4AAe8Y8Tzgyfhl9DO7s585A3s/7V2WBgNUspWHwJgKEGGxDSQP9pdjNwNYjnigW5Tmk4aFbAsbn5pctrq+7L0uU9IlQ/8TbDGri23XI42NG6RYtUR0rsuACGFiUpUH9f4uNZYlU8Es8dUt5b0LR3cA+wuU5Ai+T1eIYZgRC0YOra9rAh4=
001012:000000:0020 FAILURE: Code 0 at _J/L|WGM)`?u2bqz)X8Q:213130651
tp=P//4A//EC8KT9F/QCAAH8rvJD7vH7LvRQAAD4DfNW61L5TvTaAADz3fNy6Hv4QPUN///xivJq5S/5N/QuAAHvGPE84Mn4ZfQzu7OfOQN7P+1dlgYDVLKVh8CYChBhsQ0kD/aXYzcDWI54oFuU5pOGhWwLG5+aXLa6vuy9LlPSJUP/E2wxq4tt1yONjRukWLVEdK7LgAhhYlKVB/X+LjWWJVPBLPHVLeW9C0d3APsLlOQIvk9XiGGYEQtGDq2vawIe
ts0=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
001012:000000:0020 FAILURE: Code 0 at 4:y(r[P65@Uss?3&Ez%i:121262164
001012:000000:0020 FAILURE: Code 7890870 at 4:y(r[P65@Uss?3&Ez%i:213129639
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file /home/steve/Videos/KILLBILL2_GBR/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
steve.walton
Post by steve.walton » Tue Oct 13, 2009 5:43 am
still no good with 1.4.8 beta
disk.. ripped with AnyDVDHD to iso: KillBill2
Debug log started at Tue Oct 13 05:29:34 2009 , written by MakeMKV v1.4.8 beta linux(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta linux(x86-release) started
001012:000000:0020 FAILURE: Code 0 at b{l7w]gUb#H* o$M&X$Z:213130651
001012:000000:0020 FAILURE: Code 0 at 3#3%{&;N2|xa/If1K3R=:121262164
001012:000000:0020 FAILURE: Code 7890870 at 3#3%{&;N2|xa/If1K3R=:213129639
Post by mike admin » Wed Oct 14, 2009 10:38 am
the second log is much better, but still it is unclear what causes this error. we'll try investigate, bit it might take some time. sorry :(
tuyenvo
Post by tuyenvo » Fri Jul 23, 2010 5:15 am
Noticed this issue when trying to rip Kill Bill Vol 1 and 2 Bluray using MakeMKV on Mac OS. None of the audio problems but the color seems off in the scenes. There also seems to be a lot of discoloration with lots of green flashes and red flashes. Anyone else see the same issues? I've ripped the movies multiple times and the same issue always comes up. All other movies released around the same time look perfect.
Post by mike admin » Sat Jul 24, 2010 4:30 am
This is completely different issue, namely playback of VC-1 encoded video on Mac OS X.
