Basic Questions
Re: Basic Questions
#16 Post by Woodstock » Wed Oct 17, 2018 9:34 pm
If the glitch moves around on playback, it's more likely a problem with the player than the file. Or, more precisely, the player cannot deal with the bandwidth different sections require.
Kettykrueger
Re: Basic Questions
#17 Post by Kettykrueger » Wed Oct 17, 2018 9:39 pm
Thanks Woodstock.
I tried the file on Plex and VLC, the glitch was present at the same time in both.
Kettykrueger
Re: Basic Questions
#18 Post by Kettykrueger » Thu Oct 18, 2018 2:44 pm
Just to add, this is not the first disc to happen to.
Playing files on different platforms, glitching in the same place. Re-ripping, still have glitches but in different places.
If it’s not MakeMKV could it be the hard drive or the optical drive?
Really at a loss!
Re: Basic Questions
#19 Post by Woodstock » Thu Oct 18, 2018 5:31 pm
On BD sources, MakeMKV does a checksum of the files and tests it against the checksums on the disk; it is unusual for something to pass that process and have a glitch like you describe. Not impossible, just very, very unlikely.
If you play it in both, does the glitch occur in the same frame? Near a scene change? When there is suddenly a lot of action on the screen?
Kettykrueger
Re: Basic Questions
#20 Post by Kettykrueger » Thu Oct 18, 2018 5:33 pm
It’s the exactly same frame.
Only occurred once with this title but I’ve experience similar things with other titles.
Kettykrueger
Re: Basic Questions
#21 Post by Kettykrueger » Sun Oct 28, 2018 1:08 pm
Any other ideas, dude?
Could it be optical drive?
Re: Basic Questions
#22 Post by Woodstock » Sun Oct 28, 2018 1:50 pm
There are a lot of things it COULD be.
On a BD source where the play list consists of multiple M2TS files stitched together, scene transitions can be "rough", because the video transitions more abruptly than normal. Some segments might not even be the same resolution as the next, and the player is expected to make the transition.
Another possibility is that the glitch is intentional - but that is rare, unless you've picked the wrong play list on an obfuscated Lionsgate disk.
Do you have handbrake? One thing to try is to encode the video with it, and see if the glitch disappears. If it is a case of the transition being badly handled, SOMETIMES handbrake will smooth it out by inserting a proper key frame where the glitch happens. You don't have to encode the whole thing to test it; if you know where the glitch is, you can encode just that section and see if it fixes things.
Kettykrueger
Re: Basic Questions
#23 Post by Kettykrueger » Sun Oct 28, 2018 1:53 pm
Thanks, I’ll certainly try that.
I find it odd that it’s on most of my rips though. And this is the second time I’ve had to rip them. The first time, they all worked perfectly. This time round, many/most have corruption in them.
Kettykrueger
Re: Basic Questions
#24 Post by Kettykrueger » Fri Nov 02, 2018 5:15 pm
So that didn't work! I converted it with Handbrake and the glitch is still there.
Any other ideas?
Re: Basic Questions
#25 Post by Woodstock » Fri Nov 02, 2018 8:00 pm
What titles are you having the issue with? Maybe some others here have had the same issue and not said anything at this point...
Kettykrueger
Re: Basic Questions
#26 Post by Kettykrueger » Sun Nov 04, 2018 11:12 am
There’s too many to list!
I don’t think it’s the title/disc as I’ve ripped them before and had no problems with the outputs.
Could ripping to an external drive be a problem? Maybe it’s sleeping during ripping?
Re: Basic Questions
#27 Post by Woodstock » Sun Nov 04, 2018 2:28 pm
External drives can have issues with ripping long titles, if they're USB-powered. The drive electronics "hiccup" if the drive is spun too fast for the available power, can the operating system gets upset about it.
However, when that happens, the location varies, and MakeMKV will error out, and the file will be deleted. The same occurs if the drive (internal or external) decides to spend too much time reading a sector that has problems; The OS times out, the file is declared bad, and MakeMKV deletes it.
For MakeMKV to have saved the file, it passed a checksum test at the end, which is why this seems so weird.
Kettykrueger
Re: Basic Questions
#28 Post by Kettykrueger » Sun Nov 04, 2018 2:31 pm
Did the log file I posted earlier not give any clues?
Thanks again for taking the time to reply :D
Re: Basic Questions
#29 Post by Woodstock » Sun Nov 04, 2018 5:25 pm
The debug codes in the log are something Mike would have to look at. He holds the magic decoder ring that says what they mean.
Kettykrueger
Re: Basic Questions
#30 Post by Kettykrueger » Sun Nov 04, 2018 5:27 pm
How do we summon him?
