How do I change the codec h.265 to h.264?
hel7777
Post by hel7777 »
Hello there,
when I ripp a 4k-film makemkv uses the codec h.265. My qnap-nas and my tv don't work with h.265 but with h.264.
My problem is, I do not know how to force makemkv to use the h.264-codec. Has anyone an idea how I do manage this?
Many thanks
hel7777
Re: How do I change the codec h.265 to h.264?
Post by d00zah »
MakeMKV takes existing tracks, as authored, & moves them to an .mkv container. You'll need to re-encode (HandBrake, VidCoder, et al) to achieve what you want. Expect it to take a while for 4k.
I prefer VidCoder (based on HandBrake core) & imagine other community members can provide additional suggestions.
hel7777
Post by hel7777 »
Many thanks, I'll try it with HandBrake ...
spl147
Post by spl147 »
hel7777 wrote:Hello there,
Many thanks
hel7777
Then why rip 4K films? Just rip Blu-ray
4K Discs H265
Blu-ray Discs H264
if you don't have a 4K TV why buy 4K Discs?
Sent from my iPhone Xs Max using Tapatalk Pro
Chetwood
Post by Chetwood »
hel7777 wrote: Tue Oct 23, 2018 4:40 pmMy qnap-nas and my tv don't work with h.265 but with h.264.
Get a new NAS or TV then cause re-encoding will take ages and the file will get much bigger.
