Captain America: The Winter Soldier Problem
MasterChief580
#1 Post by MasterChief580 » Sat Oct 20, 2018 9:51 pm
I recently ordered a used blu ray version of this movie from Amazon a couple days ago and tried to rip it using MakeMKV. However, after several attempts, the application for some reason can't read the disc. It always stops reading the disc after about 10 minutes, or after reading 6.4GB of the 37GB file on the disc.
I'm using an LG USB external drive connected to my MacBook laptop, and I've ripped at least 20-30 blu rays with it without encountering this issue, which leads me to think the problem is the disc itself. This is what my blu ray disc looks like: https://www.covercentury.com/index.php? ... scscan.jpg
I've cleaned the disc and there doesn't appear to be any scratches or fingerprints on it; the disc also plays fine on my Xbox One and on my laptop using the external blu ray drive. However, I think the disc looks unusual compared to my other blu rays because there isn't any sort of image/artwork from the movie on it, the title of the film is in small font, and the texture of the top of disc feels like it's made of slightly different material. What do you guys make of this? Any help would be greatly appreciated, thank you!
Below is a copy of the errors I've been receiving in my activity log:
MakeMKV v1.12.3 darwin(x64-release) started
Optical drive "BD-ROM HL-DT-ST BDDVDRW CP40NG10 1.00d" opened in OS access mode.
File 00200.mpls was added as title #0
File 00800.mpls was added as title #1
Title #00020.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.mpls was added as title #2
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00084.m2ts was added as title #3
Title #00092.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00093.m2ts was added as title #4
Title #00097.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00136.m2ts was added as title #5
Title #00137.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/G-DRIVE sli
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '6876561408'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '6876561408'
st4evr
Re: Captain America: The Winter Soldier Problem
#2 Post by st4evr » Sun Oct 21, 2018 3:41 am
Have you read and tried this?
viewtopic.php?f=1&t=17872
MasterChief580
#3 Post by MasterChief580 » Wed Oct 24, 2018 2:52 am
I tried it using multiple versions of MakeMKV, so I don't believe that is the issue. I sent the disc back and received a refund from Amazon after I noticed that there were, in fact, a fair amount of scratches on the disc. None of the scratches were particularly large, and they weren't even visible until I held the disc close to a light source, but I must assume they affected how MakeMKV was trying to read the data.
Once I re-purchase the movie again and use another disc, I'll update the thread to see if that was the culprit.
