Title copy failing
grondinm
Title copy failing
#1 Post by grondinm » Mon Jul 19, 2010 9:19 pm
so i have been trying to copy Rambo 3 from a blu-ray but it fails every time. i just discovered the debug option. this is what is see with it on
MakeMKV v1.5.6 beta linux(x64-release) started
Debug logging enabled, log will be saved as /home/marc/MakeMKV_log.txt
File 00002.mpls was added as title #0
Title #00001.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #1
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #2
Title #00013.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory /media/Storage/BluRay/RipTemp/RAMBO_III
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at VVwkk4b9^9;d%b5?'8Lz:213130973
DEBUG: Code 0 at c'F)u:3$/0*qx%eYKEuP:213130513
DEBUG: Code 9678069 at c'F)u:3$/0*qx%eYKEuP:213129639
DEBUG: Code 0 at 5Kj{dS/n0F{T"$4~E7o1/:29397449
Failed to save title 0 to file /media/Storage/BluRay/RipTemp/RAMBO_III/title00.mkv
0 titles saved, 1 failed
i'm not to concerned at the moment with the drive speed messages. the debug errors tho what can i do about these?
after it fails it brings me back to the tittle selection screen but the main tittle is gone.
Re: Title copy failing
#2 Post by mike admin » Tue Jul 20, 2010 7:23 am
The data on disc looks wrong. Are you copying original blu-ray disc?
Please post here or email to support@makemkv.com the full MakeMKV log file, one with "tp=" lines.
grondinm
#3 Post by grondinm » Tue Jul 20, 2010 9:41 am
yes it is an original blu-ray disc. it is a box set with the first 3 rambo discs. The first 2 copied with no problem.Edit:ok scratch that none of the first 3 rambo movies copied at all. i was able to copy a bunch of other ones...not sure what is with these 3 discs. here is the full makemkv debug log:
Debug log started at Mon Jul 19 21:02:22 2010 , written by MakeMKV v1.5.6 beta linux(x64-release)
001005:0000 MakeMKV v1.5.6 beta linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/marc/MakeMKV_log.txt
DISCID=838CA7B6C511061D8B030343885FA93B2E8AC966
003307:0000 File 00002.mpls was added as title #0
003025:0000 Title #00001.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #1
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #2
003025:0000 Title #00013.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory /media/Storage/BluRay/RipTemp/RAMBO_III
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
tp=PYtF/9wdQT7kUpsHKMnG7Y05wVdeJzPVkE07JPpaWvecG0Lg8WMd4z3iVMxxPTvOOtI0ydAyWaR1PSWxc9ziV6SikVEpWwpWYbK9sfzjracsYWRM8ozKGyR9TDkzPnE1Y+xSYjXNNLaJ20mCvvZzhvbrR7G2V0tOCEPT1W6NzvOEc6TAmd42DQ6w7zhsKF0p4s0tf0PojKyl3OChvpnVloa6mELjbWcKKR84UqyGnSsow4YHqeHRvWyfnBW0=
001003:0020 DEBUG: Code 0 at VVwkk4b9^9;d%b5?'8Lz:213130973
tp=P3nA98mLRf/cHUE+5FKbByjJxu2NOcFXXicz1ZBNOyT6Wlr3nBtC4PFjHeM94lTMcT07zjrSNMnQMlmkdT0lsXPc4lekopFRKVsKVmGyvbH8462nLGFkTPKMyhskfUw5Mz5xNWPsUmI1zTS2idtJgr72c4b260extldLTghD09Vujc7zhHOkwJneNg0OsO84bChdKeLNLX9D6Iyspdzgob6Z1ZaGuphC421nCikfOFKshp0rKMOGB6nh0b1sn5wVt
ts0=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
001003:0020 DEBUG: Code 0 at c'F)u:3$/0*qx%eYKEuP:213130513
001003:0020 DEBUG: Code 9678069 at c'F)u:3$/0*qx%eYKEuP:213129639
001003:0020 DEBUG: Code 0 at 5Kj{dS/n0F{T"$4~E7o1/:29397449
005003:0000 Failed to save title 0 to file /media/Storage/BluRay/RipTemp/RAMBO_III/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jul 19 21:20:52 2010
#4 Post by mike admin » Wed Jul 21, 2010 9:13 am
Your log shows corrupted M2TS file. Does the same error happen if you use "backup" menu command with "decrypt video files" and then open backup using "open" menu command?
grondinm
#5 Post by grondinm » Wed Jul 21, 2010 10:35 am
yes it does. how can the m2ts be corrupted. the movie plays fine when i watch it on my bluray player.
