I know the web site says the only reason MakeMKV ever fails is because it can't read the disc, but my Terminator 2: Judgement Day (Skynet Edition) Blu-ray disc casts doubt on that. After multiple attempts to rip the disc using MakeMKV, I used AnyDVD to copy the entire contents of the disc to my hard drive. I then tried to use MakeMKV on the copied files only to find that it still couldn't rip them.
It goes all the way through to the end without giving me any errors or warnings, then just says the title failed to be saved. Help?! Thanks in advance!
Terminator 2 Skynet Edition fails to rip
Re: Terminator 2 Skynet Edition fails to rip
If you have debug logging turned on, what shows up in the logs?
There are reasons why MakeMKV might say a disk is failing, such as on a Lionsgate title where one or more fake playlists point to areas that do not exist on the disk.
I did have debug logging enabled, and I took a screenshot:
Does that tell you what you need? I could try again and capture the log itself.
The image you posted isn't visible.
But what we need is the text from the log, which takes up less space and is easier to post.
At the start of the log window, when you first open MakeMKV, it will tell you EXACTLY where the log is stored, so that, once you close MakeMKV, you can open the log in Notepad or whatever your favorite text editor is. The details we need are in there, and you can simply copy and paste them into your message here, preferably between CODE tags, which you can get by clicking on the button above the message box that looks like </>.
First, I don't know why the image didn't work. I saved it to my Dropbox and pasted the link (that works everywhere else) to my message. Go figure.
Second, I re-ran the failing rip process this morning to generate the following log. This time I did it from the disc, but I get the same error when the disc's content is copied to the hard drive. It's clearly not a disc-reading issue.
Debug log started at Fri Oct 05 13:57:38 2018 , written by MakeMKV v1.12.3 win(x64-release)
001005:0000 MakeMKV v1.12.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\John/MakeMKV_log.txt
DEBUG: Code 2365587456 at KP2EQg,Ybj})Rn!@:29405660
DEBUG: Code 0 at KP2EQg,Ybj})Rn!@:213139943
DEBUG: Code 0 at ug!Y?M}h37%"DxLT:29400623
DEBUG: Code 2147483648 at KP2EQg,Ybj})Rn!@:213133250
DAFD=PAAAADAAAAEABDQkEGQECAQ==
DCE=xrBZBewA4oeK++2uC0VuSq7k2fune66LH0v1fSFQ/+ALa+B/05t23P2KJrLwzDurEc2qbyAWxTq5e37IPmcLbt9oJ9qyWepE0pAs1LErGgX/bpTZVzhJ3lWLgr2wMM4Dh/OXmpq5M304kx82ClxGARziWlcerXhEbQ==
DISCID=28A310A87D944CB3CF4AB5B7DAB49CE67E009D5C
003307:0000 File 00016.mpls was added as title #0
003025:0000 Title #00137.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.mpls has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00018.mpls was added as title #1
003307:0000 File 00019.mpls was added as title #2
003025:0000 Title #00080.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00017.mpls was added as title #3
003309:0000 Title 00100.mpls is equal to title 00017.mpls and was skipped
003025:0000 Title #00139.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00156.mpls was added as title #4
003309:0000 Title 00020.mpls is equal to title 00017.mpls and was skipped
003025:0000 Title #00001.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #5
003025:0000 Title #00005.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #6
003025:0000 Title #00007.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #7
003025:0000 Title #00010.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00013.m2ts was added as title #8
003307:0000 File 00014.m2ts was added as title #9
003307:0000 File 00015.m2ts was added as title #10
003307:0000 File 00016.m2ts was added as title #11
003025:0000 Title #00017.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #12
003025:0000 Title #00019.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.m2ts was added as title #13
003025:0000 Title #00021.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00022.m2ts was added as title #14
003307:0000 File 00023.m2ts was added as title #15
003307:0000 File 00024.m2ts was added as title #16
003025:0000 Title #00025.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00026.m2ts was added as title #17
003025:0000 Title #00027.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00030.m2ts was added as title #18
003307:0000 File 00031.m2ts was added as title #19
003307:0000 File 00032.m2ts was added as title #20
003025:0000 Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00134.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00136.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00139.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00140.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00141.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00142.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00145.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00157.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00159.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00160.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00161.m2ts was added as title #21
003307:0000 File 00162.m2ts was added as title #22
003025:0000 Title #00164.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00188.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00190.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00192.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00193.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00194.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00195.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00196.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00197.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00198.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00199.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00201.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00202.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00203.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00204.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00206.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00207.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00208.m2ts was added as title #23
003025:0000 Title #00209.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00210.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00211.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00212.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00213.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00214.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00215.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00216.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00217.m2ts was added as title #24
003025:0000 Title #00218.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00219.m2ts was added as title #25
003025:0000 Title #00220.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00221.m2ts was added as title #26
003307:0000 File 00224.m2ts was added as title #27
003025:0000 Title #00225.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00226.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00228.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00229.m2ts was added as title #28
003025:0000 Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00235.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00236.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00237.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00238.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00239.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00240.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00241.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00242.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00243.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00244.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00245.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00246.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00247.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00248.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00250.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00251.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00252.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00253.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00254.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00255.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00256.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00257.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00258.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00259.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00260.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00261.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00262.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00263.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00264.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00265.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00266.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00267.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00268.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00269.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00270.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00271.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00272.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00273.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00274.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00275.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00276.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00277.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00278.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00279.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00280.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00281.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00282.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00283.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00284.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00285.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00286.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00287.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00288.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00289.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00290.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00291.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00294.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00105.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory D:/Video/Terminator_2
AV sync issues in D:/Video/Terminator_2/Terminator_2_t01.mkv
AV sync in 1 at 0:00:00 (32ms) : 3 frame(s) dropped to reduce audio skew to +9.708ms
AV sync in 2 at 0:00:00 (32ms) : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync in 3 at 0:00:00 (32ms) : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync in 4 at 0:00:00 (32ms) : 1 frame(s) dropped to reduce audio skew to +9.708ms
AV sync in 1,2,3,4 at 0:00:00 (41.708ms) : encountered overlapping frame, audio skew is +9.708ms
AV sync in 2,3,4 at 0:15:31.680 (21.541ms) : encountered overlapping frame, audio skew is +31.25ms
AV sync in 1 at 0:15:31.680 (0.208ms) : encountered overlapping frame, audio skew is +9.916ms
AV sync in 2,3,4 at 0:15:57.247 (0.791ms) : encountered overlapping frame, audio skew is +32.041ms
AV sync in 1 at 0:15:57.247 (0.791ms) : encountered overlapping frame, audio skew is +10.708ms
AV sync in 2,3,4 at 0:17:59.369 (22ms) : encountered overlapping frame, audio skew is +54.041ms
AV sync in 2,3,4 at 0:17:59.424 (32ms) : 1 frame(s) dropped to reduce audio skew to +22.041ms
AV sync in 1 at 0:17:59.369 (0.666ms) : encountered overlapping frame, audio skew is +11.375ms
AV sync in 2,3,4 at 0:18:31.235 (6.833ms) : encountered overlapping frame, audio skew is +28.875ms
AV sync in 1 at 0:18:31.235 (6.833ms) : encountered overlapping frame, audio skew is +18.208ms
AV sync in 2,3,4 at 0:33:16.577 (1.208ms) : encountered overlapping frame, audio skew is +30.083ms
AV sync in 1 at 0:33:16.577 (1.208ms) : encountered overlapping frame, audio skew is +19.416ms
AV sync in 2,3,4 at 0:36:21.929 (24.166ms) : encountered overlapping frame, audio skew is +54.25ms
AV sync in 2,3,4 at 0:36:21.984 (32ms) : 1 frame(s) dropped to reduce audio skew to +22.25ms
AV sync in 1 at 0:36:21.929 (2.833ms) : encountered overlapping frame, audio skew is +22.25ms
AV sync in 1 at 0:36:21.952 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +11.583ms
AV sync in 2,3,4 at 0:39:23.486 (11.625ms) : encountered overlapping frame, audio skew is +33.875ms
AV sync in 1 at 0:39:23.486 (0.958ms) : encountered overlapping frame, audio skew is +12.541ms
AV sync in 2,3,4 at 0:39:41.462 (7.708ms) : encountered overlapping frame, audio skew is +41.583ms
AV sync in 1 at 0:39:41.462 (7.708ms) : encountered overlapping frame, audio skew is +20.25ms
AV sync in 2,3,4 at 1:03:50.368 (22.208ms) : encountered overlapping frame, audio skew is +63.791ms
AV sync in 2,3,4 at 1:03:50.432 (32ms) : 1 frame(s) dropped to reduce audio skew to +31.791ms
AV sync in 1 at 1:03:50.368 (0.875ms) : encountered overlapping frame, audio skew is +21.125ms
AV sync in 1 at 1:03:50.389 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +10.458ms
AV sync in 2,3,4 at 1:04:50.928 (15.5ms) : encountered overlapping frame, audio skew is +47.291ms
AV sync in 2,3,4 at 1:04:50.976 (32ms) : 1 frame(s) dropped to reduce audio skew to +15.291ms
AV sync in 1 at 1:04:50.928 (4.833ms) : encountered overlapping frame, audio skew is +15.291ms
AV sync in 2,3,4 at 1:06:36.867 (12.833ms) : encountered overlapping frame, audio skew is +28.125ms
AV sync in 1 at 1:06:36.867 (2.166ms) : encountered overlapping frame, audio skew is +17.458ms
AV sync in 1 at 1:07:10.693 (9.208ms) : encountered overlapping frame, audio skew is +26.666ms
AV sync in 1 at 1:07:10.720 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +16ms
AV sync in 2,3,4 at 1:07:10.693 (30.541ms) : encountered overlapping frame, audio skew is +58.666ms
AV sync in 2,3,4 at 1:07:10.752 (32ms) : 1 frame(s) dropped to reduce audio skew to +26.666ms
AV sync in 2,3,4 at 1:08:46.664 (29.125ms) : encountered overlapping frame, audio skew is +55.791ms
AV sync in 2,3,4 at 1:08:46.720 (32ms) : 1 frame(s) dropped to reduce audio skew to +23.791ms
AV sync in 1 at 1:08:46.664 (7.791ms) : encountered overlapping frame, audio skew is +23.791ms
AV sync in 1 at 1:08:46.688 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +13.125ms
AV sync in 2,3,4 at 1:09:26.620 (11.416ms) : encountered overlapping frame, audio skew is +35.208ms
AV sync in 1 at 1:09:26.620 (0.75ms) : encountered overlapping frame, audio skew is +13.875ms
AV sync in 2,3,4 at 1:12:07.531 (17.25ms) : encountered overlapping frame, audio skew is +52.458ms
AV sync in 2,3,4 at 1:12:07.584 (32ms) : 1 frame(s) dropped to reduce audio skew to +20.458ms
AV sync in 1 at 1:12:07.531 (6.583ms) : encountered overlapping frame, audio skew is +20.458ms
AV sync in 1 at 1:12:07.552 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +9.791ms
AV sync in 2,3,4 at 1:12:59.583 (12ms) : encountered overlapping frame, audio skew is +32.458ms
AV sync in 1 at 1:12:59.583 (1.333ms) : encountered overlapping frame, audio skew is +11.125ms
AV sync in 2,3,4 at 1:21:17.414 (25.333ms) : encountered overlapping frame, audio skew is +57.791ms
AV sync in 2,3,4 at 1:21:17.472 (32ms) : 1 frame(s) dropped to reduce audio skew to +25.791ms
AV sync in 1 at 1:21:17.414 (4ms) : encountered overlapping frame, audio skew is +15.125ms
AV sync in 2,3,4 at 1:21:44.441 (13ms) : encountered overlapping frame, audio skew is +38.791ms
AV sync in 1 at 1:21:44.441 (2.333ms) : encountered overlapping frame, audio skew is +17.458ms
AV sync in 2,3,4 at 1:34:03.471 (10.041ms) : encountered overlapping frame, audio skew is +48.833ms
AV sync in 2,3,4 at 1:34:03.520 (32ms) : 1 frame(s) dropped to reduce audio skew to +16.833ms
AV sync in 1 at 1:34:03.471 (10.041ms) : encountered overlapping frame, audio skew is +27.5ms
AV sync in 1 at 1:34:03.498 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +16.833ms
AV sync in 2,3,4 at 1:34:39.823 (42.541ms) : audio gap - 1.329 missing frame(s)
004008:0010 AV sync issue in stream 1 at 1:34:39.801 with duration of 63.875ms : audio gap - 5.988 missing frame(s)
004008:0010 AV sync issue in stream 2,3,4 at 1:56:49.306 with duration of 96ms : 3 overlapping frame(s) dropped at segment boundary
AV sync in 2,3,4 at 1:56:49.306 (16ms) : encountered overlapping frame, audio skew is +16ms
004008:0010 AV sync issue in stream 1 at 1:56:49.295 with duration of 85.333ms : 8 overlapping frame(s) dropped at segment boundary
AV sync in 1 at 1:56:49.295 (5.333ms) : encountered overlapping frame, audio skew is +5.333ms
AV sync in 2,3,4 at 1:57:09.313 (24.583ms) : encountered overlapping frame, audio skew is +40.583ms
AV sync in 1 at 1:57:09.313 (3.25ms) : encountered overlapping frame, audio skew is +8.583ms
AV sync in 2,3,4 at 2:01:58.853 (28.75ms) : encountered overlapping frame, audio skew is +69.333ms
AV sync in 2,3,4 at 2:01:58.922 (32ms) : 1 frame(s) dropped to reduce audio skew to +37.333ms
AV sync in 1 at 2:01:58.853 (7.416ms) : encountered overlapping frame, audio skew is +16ms
AV sync in 2,3,4 at 2:05:06.290 (18.75ms) : encountered overlapping frame, audio skew is +56.083ms
AV sync in 2,3,4 at 2:05:06.346 (32ms) : 1 frame(s) dropped to reduce audio skew to +24.083ms
AV sync in 1 at 2:05:06.290 (8.083ms) : encountered overlapping frame, audio skew is +24.083ms
AV sync in 1 at 2:05:06.314 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +13.416ms
AV sync in 2,3,4 at 2:11:53.822 (19.875ms) : encountered overlapping frame, audio skew is +43.958ms
AV sync in 2,3,4 at 2:11:53.866 (32ms) : 1 frame(s) dropped to reduce audio skew to +11.958ms
AV sync in 1 at 2:11:53.822 (9.208ms) : encountered overlapping frame, audio skew is +22.625ms
AV sync in 1 at 2:11:53.845 (10.666ms) : 1 frame(s) dropped to reduce audio skew to +11.958ms
AV sync in 1,2,3,4 at 2:12:34.363 (3.5ms) : encountered overlapping frame, audio skew is +15.458ms
001003:0020 DEBUG: Code 45045000 at n]b0~$o-o?V5vbG:khR:121265821
001003:0020 DEBUG: Code 0 at 7(:bJRPje>S[z:y!Z~".~:121267661
005003:0000 Failed to save title 1 to file D:/Video/Terminator_2/Terminator_2_t01.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Oct 05 14:46:26 2018
- Contact:
bug in 1.12.3 - either un-select all subtitles, or use previous version. fix coming soon...
Nice! I'm looking forward to the fix. I'll be happy to beta test a pre-release version on this particular problem if you like. Either way, thanks!
After you copy the public Dropbox link to your clipboard, just change ?dl=0 to ?raw=1 at the end of the URL.Phileosophos wrote: ↑Fri Oct 05, 2018 2:49 pmFirst, I don't know why the image didn't work. I saved it to my Dropbox and pasted the link (that works everywhere else) to my message.
If you leave the link as ?dl=0, although it will look like a link to an image, it will really link to the interstitial non-embeddable Dropbox page that frames the image or invites people to signup for Dropbox.
I too am having the same issue with trying to rip Terminator 2 Judgment Day. I have ripped several other disks and my Blu Ray drive is new so I don't think that is the issue. I believe that I am having issues because it is a Lionsgate Blu Ray disk. I have yet to figure out what to try to get around the issue of "read error". I have cleaned my disk, and it have no visible flaws. Other disks rip just fine. I believe that I am having the Lionsgate issue. I tried to get MakeMKV use the Java Runtime Enviroment, but either I'm doing it wrong, or it just isn't the solution to my problem. When I have MakeMKV read the disk it IDs it as "LOGICAL_VOLUME_ID" and it only finds two items to rip. The first file is 36 chapters at 21.7 GB , and the second file is only 347.9 MB with no chapters listed. Neither file will rip to the hard drive without error. Is there any solution yet to how to get around this Lionsgate problem?
