Solo A Star Wars Story Blu-Ray issue
editboy23
Post by editboy23 »
I've tried all the titles and get the same errors for each one:
Error 'OS error - A device which does not exist was specified' occurred while reading '\Device\CdRom1' at offset '193198080'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '193198080'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00810.m2ts' at offset '193198080'
I have the latest version of MakeMKV
I'm on a PC
Anybody else having issues?
Re: Solo A Star Wars Story Blu-Ray issue
Your drive has gone off-line as far as Windows knows. You may have to reset the computer for Windows to find the drive again.
MakeMKV can't talk to the drive if Windows doesn't think it is there.
editboy23
Post by editboy23 »
Well I just successfully ripped it with DVDFab Blu-Ray Ripper with the exact same setup. So it's not the disk and it's not the drive. It must be MakeMKV.
Windows says the hardware has gone away, and it's MakeMKV's fault?
OK, that's an interesting twist.
Oh, back to one of your original questions, others have ripped this title without issue, other than figuring out which of the three play lists was the correct one for English. In those cases, there were no reports of drives going "off line" during the rip.
Lovely Rita
Post by Lovely Rita »
editboy23 wrote:
Thu Oct 04, 2018 8:58 pm
Well, I successfully ripped Solo with MakeMKV with my setup. No question you’ve got a problem with your setup.
Registered User :wink:
Buy MakeMKV
editboy23
Post by editboy23 »
It's definitely weird, I've never had this issue before.
I tried all the titles with the same result.
I'm just telling you what happened, process of elimination says it's the software.
I may try another title with it to see if it's just that particular title or the setup.
derpheadjones
Post by derpheadjones »
Is this a redbox disc? What playlist are you trying to rip?
editboy23
Post by editboy23 »
It was a Redbox Blu-Ray. I can't remember the specific title I chose but it was the English version of the main title.
I tried all of them as a test with the same result.
