October Beta Serial Key
CHMarvin
Post by CHMarvin »
Hey, when will be the release for the October Beta Serial Key? Ty.
Re: October Beta Serial Key
Approximately the same time Mike posts it. It definitely won't be before that, though.
In the mean time, you can set your system date back to prior to the expiration of the current key, start MakeMKV, then reset your date to the current date. MakeMKV only checks for key expiration at start-up.
spl147
Post by spl147 »
Or you can just buy the program!
