so i have been trying to copy Rambo 3 from a blu-ray but it fails every time. i just discovered the debug option. this is what is see with it on
MakeMKV v1.5.6 beta linux(x64-release) started
Debug logging enabled, log will be saved as /home/marc/MakeMKV_log.txt
File 00002.mpls was added as title #0
Title #00001.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #1
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #2
Title #00013.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory /media/Storage/BluRay/RipTemp/RAMBO_III
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at VVwkk4b9^9;d%b5?'8Lz:213130973
DEBUG: Code 0 at c'F)u:3$/0*qx%eYKEuP:213130513
DEBUG: Code 9678069 at c'F)u:3$/0*qx%eYKEuP:213129639
DEBUG: Code 0 at 5Kj{dS/n0F{T"$4~E7o1/:29397449
Failed to save title 0 to file /media/Storage/BluRay/RipTemp/RAMBO_III/title00.mkv
0 titles saved, 1 failed
i'm not to concerned at the moment with the drive speed messages. the debug errors tho what can i do about these?
after it fails it brings me back to the tittle selection screen but the main tittle is gone.
Title copy failing
Re: Title copy failing
The data on disc looks wrong. Are you copying original blu-ray disc?
Please post here or email to support@makemkv.com the full MakeMKV log file, one with "tp=" lines.
grondinm
yes it is an original blu-ray disc. it is a box set with the first 3 rambo discs. The first 2 copied with no problem.Edit:ok scratch that none of the first 3 rambo movies copied at all. i was able to copy a bunch of other ones...not sure what is with these 3 discs. here is the full makemkv debug log:
Debug log started at Mon Jul 19 21:02:22 2010 , written by MakeMKV v1.5.6 beta linux(x64-release)
001005:0000 MakeMKV v1.5.6 beta linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/marc/MakeMKV_log.txt
DISCID=838CA7B6C511061D8B030343885FA93B2E8AC966
003307:0000 File 00002.mpls was added as title #0
003025:0000 Title #00001.mpls has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #1
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #2
003025:0000 Title #00013.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory /media/Storage/BluRay/RipTemp/RAMBO_III
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
tp=PYtF/9wdQT7kUpsHKMnG7Y05wVdeJzPVkE07JPpaWvecG0Lg8WMd4z3iVMxxPTvOOtI0ydAyWaR1PSWxc9ziV6SikVEpWwpWYbK9sfzjracsYWRM8ozKGyR9TDkzPnE1Y+xSYjXNNLaJ20mCvvZzhvbrR7G2V0tOCEPT1W6NzvOEc6TAmd42DQ6w7zhsKF0p4s0tf0PojKyl3OChvpnVloa6mELjbWcKKR84UqyGnSsow4YHqeHRvWyfnBW0=
001003:0020 DEBUG: Code 0 at VVwkk4b9^9;d%b5?'8Lz:213130973
tp=P3nA98mLRf/cHUE+5FKbByjJxu2NOcFXXicz1ZBNOyT6Wlr3nBtC4PFjHeM94lTMcT07zjrSNMnQMlmkdT0lsXPc4lekopFRKVsKVmGyvbH8462nLGFkTPKMyhskfUw5Mz5xNWPsUmI1zTS2idtJgr72c4b260extldLTghD09Vujc7zhHOkwJneNg0OsO84bChdKeLNLX9D6Iyspdzgob6Z1ZaGuphC421nCikfOFKshp0rKMOGB6nh0b1sn5wVt
ts0=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
001003:0020 DEBUG: Code 0 at c'F)u:3$/0*qx%eYKEuP:213130513
001003:0020 DEBUG: Code 9678069 at c'F)u:3$/0*qx%eYKEuP:213129639
001003:0020 DEBUG: Code 0 at 5Kj{dS/n0F{T"$4~E7o1/:29397449
005003:0000 Failed to save title 0 to file /media/Storage/BluRay/RipTemp/RAMBO_III/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jul 19 21:20:52 2010
Your log shows corrupted M2TS file. Does the same error happen if you use "backup" menu command with "decrypt video files" and then open backup using "open" menu command?
grondinm
yes it does. how can the m2ts be corrupted. the movie plays fine when i watch it on my bluray player.
