Expiration dates
jeep_dawg
Expiration dates
You know, it would be rally handy if the expiration times were either posted to the forum or in the software. It's really annoying to get a DVD not realizing the software key has expired!
Bathel
Re: Expiration dates
Go to the Help option, then About. It list the expiration date.
Also, you always have the option of actually purchasing the software and then you don't have to worry about the expiration of the registration key. If you're using it as "freeware" you're kind barking up the wrong tree if you want any sympathy....
Bathel
Open up the program... click help.... click about... it will show you the expiration date of the registration key.
Also... you can purchase a license and you won't have to worry about expiration anymore. If you're using this as a "freeware" you really don't have much room to be "annoyed"
ishcabittle
There is a solution, tho... buy a product key and your application will always work. Otherwise wait a day or two for your free application to get its update.
Lovely Rita
