MacGruber - Which Version?
mike_mgoblue
Post by mike_mgoblue »
I am trying to figure out which version of MacGruber is the correct one to download from the Blu-ray.
The first has the following information:
Title information
Source file name: 00810.mpls
Duration: 1:30:16
Chapters count: 20
Segment count: 1
Segment map: 10
File name: MacGruber_t00.mkv
The second has the following information:
Title information
Source file name: 00802.mpls
Duration: 1:34:53
Chapters count: 20
Segment count: 1
Segment map: 802
File name: MacGruber_t01.mkv
Does anyone know which version is the correct version or what the difference is between these two versions? ... Thank you.
mike_mgoblue
Re: MacGruber - Which Version?
I have now learned the shorter version is actually a larger file and it is the "Theatrical" version. The longer version is actually a shorter file and is an "Extended" version. It was confusing to me that the "longer" version was actually a smaller file.
dbtayag
Post by dbtayag »
mike_mgoblue wrote: Wed Sep 26, 2018 9:11 pm I have now learned the shorter version is actually a larger file and it is the "Theatrical" version. The longer version is actually a shorter file and is an "Extended" version. It was confusing to me that the "longer" version was actually a smaller file.
The reason for this is because the theatrical version uses a higher bitrate with the AVC video codec while the extended version uses a smaller bitrate with the VC-1 video codec.
