macOS 10.14 Mojave Compatibility
Craig85311
Hi all, have any of you used MakeMKV on 10.14 Mojave? Would like to know if this works before I upgrade, as I've not seen anything in their release notes indicating compatibility. Thanks!
Re: macOS 10.14 Mojave Compatibility
I don't know but I intend to find out tonight.
So I upgraded, launched MakeMKV and popped in a disk. I got a bunch of scsi errors but I cleared the error log, restarted, and it all worked great. Just tested the output in VLC and it had zero problems.
I also upgraded and received a slew of SCSI errors along with my drive's motor assembly sounding like it was failing (made a heck of a racket). Cleared the Error Log and tried again, but same effect. Works fine in Windows so assuming Mohave has changed something in the drive access protocols. So will be using Windows for the time being. Using a Samsung SE-506BB portable BRD.
Low Winter Sun
No SCSI errors here with Mojave, just a nice errorless copy.
I have a mix of LG BE16NU50 drives and some Pioneer drives.
The Pioneer drives work with MakeMKV without any issues, but the LG drives do not even show up as an option to process from.
When mounting Blu Ray or DVD media, the Pioneer drives mount as optical media, but the LG drives mount like they are a DMG file. I can read from both in the finder, but MakeMKV refuses to work with media mounted in the LG drives.
I just updated to Mojave and am now getting this:
I have downloaded v1.12.3 which I assume is the latest as that is what I am offered on the web site?
- Screen Shot 2018-10-22 at 12.46.42 AM.png (27.5 KiB) Viewed 21286 times
