Deadpool 2
kingston12
Deadpool 2
#1 Post by kingston12 » Sat Sep 22, 2018 6:22 pm
I have just purchased the new Deadpool 2 UHD, and it won't rip due to hashcheck errors.
'I checked the latest hashed key file and that title is included, and I am sure I have seen some posts here from people who have done it successfully?
Re: Deadpool 2
#2 Post by Woodstock » Sat Sep 22, 2018 7:40 pm
Does this describe the situation?
viewtopic.php?f=1&t=17872
kingston12
Re: Deadpool 2
#3 Post by kingston12 » Sun Sep 23, 2018 10:53 am
Woodstock wrote: Sat Sep 22, 2018 7:40 pm Does this describe the situation?
Thanks, but not really. I am using 1.12.3, and am getting hashcheck errors like:
The source file '/BDMV/STREAM/00068.m2ts' is corrupt or invalid at offset 26490660864, attempting to work around
AV sync issue in stream 1 at 0:55:17.855 with duration of 12ms : audio gap - 14.4 missing frame(s)
The AV sync issues seem to be new compared to when I tried yesterday.
TheShoe
Re: Deadpool 2
#4 Post by TheShoe » Sun Sep 23, 2018 2:28 pm
this situation happens to me on a semi regular basis. disc cleaning sometimes works, though i wonder if it is really just a random occurance that the drive has trouble reading the disc. prior to uhd, i never had to clean a disc.
i find switching drives to be more helpful. i have an asus and an lg, usb3 and sata connected respectively. when one fails the other usually works fine
sharpie00
Re: Deadpool 2
#5 Post by sharpie00 » Sun Sep 23, 2018 7:35 pm
Deadpool 2 UHD on a LG BE16NU50 works perfectly.
