Jurassic World Fallen Kingdom
Swaps
#1 Post by Swaps » Thu Sep 20, 2018 3:42 pm
Anyone get this to work? Just wondering if I have a bad disc. Thanks.
Re: Jurassic World Fallen Kingdom
#2 Post by Woodstock » Thu Sep 20, 2018 5:49 pm
Some indication of the errors you're receiving would be helpful...
st4evr
#3 Post by st4evr » Thu Sep 20, 2018 6:27 pm
Swaps wrote: Thu Sep 20, 2018 3:42 pm Anyone get this to work? Just wondering if I have a bad disc. Thanks.
Yes, it has been ripped successfully. And as Woodstock implies, simply saying "it does not work" does not help us help you.
Something like this could be useful for us in trying to assist you:
viewtopic.php?f=16&t=17982
viewtopic.php?f=12&t=17983
#4 Post by Billycar11 » Thu Sep 20, 2018 10:16 pm
i dont see Jurassic World Fallen Kingdom in the hashed keys yet so thats probably why
st4evr
#5 Post by st4evr » Thu Sep 20, 2018 10:32 pm
Billycar11 wrote: Thu Sep 20, 2018 10:16 pm i dont see Jurassic World Fallen Kingdom in the hashed keys yet so thats probably why
At least one disc was supported as of 10 days ago. It is listed as "JWFK_UPK75". The movie title is not spelled out as most of the other titles.
#6 Post by Billycar11 » Thu Sep 20, 2018 10:35 pm
i see there are even 2 versions today thanks for the info
Swaps
#7 Post by Swaps » Thu Sep 20, 2018 11:23 pm
Saving 1 titles into directory F:/video
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '13910962176'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '13910962176'
Failed to save title 0 to file F:/video/Jurassic_World_Fallen_Kingdom_t00.mkv
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
#8 Post by Woodstock » Fri Sep 21, 2018 2:33 am
Those error messages are consistent with the optical drive trying to read a bad sector and the operating system getting impatient (time-out errors).
External USB-powered drives can also get that when they spin too fast for the available power, but I don't remember seeing any USB-powered UHD-capable drives out there.
Swaps
#9 Post by Swaps » Fri Sep 21, 2018 9:49 pm
Thanks. I exchanged it and ripped no problem.
HoneyBadger
#10 Post by HoneyBadger » Wed Sep 26, 2018 7:17 pm
Even with both the current hashed keys, I could not decrypt the bluray (I have the Canadian version if that means anything different).
Sent the dump to svq@makemkv.com so hopefully a third key should be added soon.
Zealous
#11 Post by Zealous » Sun Sep 30, 2018 3:36 am
I have a USB powered drive, from what has been said in the thread there is no way UHD can be ripped by one? Bluerays work fine, never had an issue till i attempted 4k disks. Makemkv attempts to read and then returns with no disk detected.
#12 Post by Woodstock » Sun Sep 30, 2018 6:30 pm
Your drive must be capable of doing BD-XL reads, which most USB drives are not. There are USB housings for SATA drives, which can have a SATA UHD-friendly drive installed.
st4evr
#13 Post by st4evr » Sun Sep 30, 2018 11:53 pm
Zealous wrote: Sun Sep 30, 2018 3:36 am I have a USB powered drive, from what has been said in the thread there is no way UHD can be ripped by one? Bluerays work fine, never had an issue till i attempted 4k disks. Makemkv attempts to read and then returns with no disk detected.
Well. Almost sounds like you need to start from the beginning.
Read:
https://www.myce.com/news/the-ultimate- ... ive-83254/
viewtopic.php?f=16&t=16832
viewtopic.php?f=16&t=17829
Zealous
#14 Post by Zealous » Wed Oct 10, 2018 11:44 am
st4evr wrote: Sun Sep 30, 2018 11:53 pm
Read:
Yep, i have been doing a lot of reading. Pick up a BC-12D2HT, just installed it tonight but getting no disk inserted running fw 3.01. Trying to work this one out currently.
guitarbruce
#15 Post by guitarbruce » Thu Sep 19, 2019 3:37 pm
I too am unsuccessful with braking Jurassic World Fallen Kingdom. The longest title in the list is #14 (2:08:10) which handbrake does by default. The resulting "brake" is only about 5 minutes long (not the entire movie). I've tried doing #14 manually with the same result. All the other titles in the list are under 2 minutes.
Clues?
