pqeiwrhfglzd
Post
by pqeiwrhfglzd » Thu Sep 20, 2018 1:56 am
This is what it's spitting out at me when I try to open the disc (folder). It plays just fine in VLC. Attached is log file, which includes failed attempts at opening disc1 and disc2. Disc3 opened fine.
Opening files on harddrive at ...Satantango_dvd/Disc1/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Post
by Woodstock » Thu Sep 20, 2018 2:06 am
Are the results the same if you use version 1.12.2?
How were the image files created? Do you get the same error if you rip from the original media?
pqeiwrhfglzd
Post
by pqeiwrhfglzd » Thu Sep 20, 2018 2:17 am
Woodstock wrote: Thu Sep 20, 2018 2:06 am
Yes
I don't know. I no longer have access to the original media.
Post
by Woodstock » Thu Sep 20, 2018 12:53 pm
DVD ISOs created with tools like dd on Linux or Mac should read fine, assuming there were no read errors when they were created. BD ISOs are far more finicky. I've had mixed results if the encryption was removed by the software that made the ISO.
pqeiwrhfglzd
Post
by pqeiwrhfglzd » Thu Sep 20, 2018 5:00 pm
Woodstock wrote: Thu Sep 20, 2018 12:53 pm
I tried that with Disc1 after seeing a thread on here. No dice.
