Satantango (1994) — Failed to open disc
pqeiwrhfglzd
Post by pqeiwrhfglzd »
This is what it's spitting out at me when I try to open the disc (folder). It plays just fine in VLC. Attached is log file, which includes failed attempts at opening disc1 and disc2. Disc3 opened fine.
Opening files on harddrive at ...Satantango_dvd/Disc1/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
MakeMKV_log.txt
(1.65 KiB) Downloaded 460 times
Disc2_ifo.zip
(49.63 KiB) Downloaded 495 times
Disc1_ifo.zip
(54.79 KiB) Downloaded 489 times
Re: Satantango (1994) — Failed to open disc
Are the results the same if you use version 1.12.2?
How were the image files created? Do you get the same error if you rip from the original media?
pqeiwrhfglzd
Woodstock wrote:
Thu Sep 20, 2018 2:06 am
Yes
I don't know. I no longer have access to the original media.
DVD ISOs created with tools like dd on Linux or Mac should read fine, assuming there were no read errors when they were created. BD ISOs are far more finicky. I've had mixed results if the encryption was removed by the software that made the ISO.
pqeiwrhfglzd
Woodstock wrote:
Thu Sep 20, 2018 12:53 pm
I tried that with Disc1 after seeing a thread on here. No dice.
MakeMKV_log.txt
(1.06 KiB) Downloaded 499 times
