Hello i am new on this forum.
Makemkv just works fine, source is a DVD jurassic park, if i play it on my homecinema, there is a very good video en audio.
But the subtitle is not visible , contains a format Vobsub ( codec : S_VOBSUB) , also on PC Powerdvd can't sea the sub as well.
What can i do about it ?
Jan
Subtitle
setarip_old
Re: Subtitle
Hi!
Software players have been slow to incorporate "PGS" subtitle format playback capability. Try VLC v.1.1.0...
Re: Subtitle
PGS is from Blu-ray and HD DVD. He was ripping a DVD, so the subtitle format should be VOBSUB (which he also said it was).setarip_old wrote:Software players have been slow to incorporate "PGS" subtitle format playback capability. Try VLC v.1.1.0...
There should be pretty good vobsub support in most players, but I'm not sure about PowerDVD. VLC 1.1.0 is a good suggestion for the PC, though.
Veen69: What player are you using in your homecinema?
Re: Subtitle
trondmm
thanks for you respond, mij home cinemaplayer is Samsung HT-5500 blue ray.
