Predator 2
beatsntoons
Predator 2
Post by beatsntoons »
Has anyone managed to rip this? I'm on my 2nd disc, and the rip just hangs and eventually fails (0 titles saved).
Just curious if this is something others have seen for this title.
st4evr
Re: Predator 2
Post by st4evr »
Yes, this has been succesfully ripped.
Read this:
viewtopic.php?f=16&t=17982
As it applies to you as well and then update this post.
beatsntoons
Re: Predator 2
Could it be two dud discs in a row? The drive rips other movies without issues. This was Predator 2 today. I'll try ANOTHER clean, but I've cleaned this so much, I might go back to the store and ask for another disc.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31066091520'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31066091520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31066423296'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31066423296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31066816512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31066945536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31066945536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31067467776'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31067467776'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31067664384'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31067664384'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31067731968'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31067731968'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31068125184'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31068125184'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31068254208'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31068254208'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31068911616'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31072186368'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31074287616'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31074287616'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31074484224'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31074484224'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '31074545664'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '31074545664'
st4evr
Re: Predator 2
Post by st4evr »
Did you try #2 from the link that was provided? Slow down and read all that was provided. It may not be the disc.
What version of MakeMKV are you using?
beatsntoons
Re: Predator 2
Yes I tried 1.12.2 but it also failed at the same point. (User cancelled after about 1hr 12mins). Initial run was with 1.12.3 which is where the problems started.
I also tried manually copying the files to my drive through Windows but the disc stops being read at the same point (roughly 50-60% in after about an hour)
Errors below, mostly different offset values from above. Looks like it's encountering errors on the disc, then the drive basically it stops reading from then on? Am I reading that right?
If I clean this disc anymore, I'll have a disc half the height of what I bought :D
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30460342272'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30460342272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30460409856'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30460409856'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30460538880'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30460538880'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30460735488'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30460735488'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30460932096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30463229952'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30463229952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30463358976'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30463358976'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30488260608'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '30488850432'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '30488850432'
Failed to save title 0 to file D:/Video/Predator_2/Predator_2_t00.mkv
beatsntoons
Re: Predator 2
Tried stripping everything out of my PC except the OS drive, GPU and ODD
Still got errors. Full log attached.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47211608064'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '47211608064'
DEBUG: Code 3221225628 at ,i4-.2g.]3n$zk0ZB=:121262969
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47211675648'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '47211675648'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47211804672'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47214360576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47214753792'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47214821376'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47214882816'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '47214882816'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47217635328'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218028544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '47218028544'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218096128'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218360320'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218489344'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218685952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '47218753536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '47218753536'
DEBUG: Code 100864261 at ,i4-.2g.]3n$zk0ZB=:121262969
DEBUG: Code 0 at n6_l4"9@ad(W>C?k_j*r:121263176
DEBUG: Code 0 at wz7oQ0FT$kUdK(c42RCM:29394068
DEBUG: Code 0 at n6_l4"9@ad(W>C?k_j*r:29394551
DEBUG: Code 23056032 at n6_l4"9@ad(W>C?k_j*r:29393286
DEBUG: Code 0 at O}/})]dH|,$|uPs991YUL:213135550
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file F:/Video/Predator_2/Predator_2_t00.mkv
MakeMKV_log.txt
(28.71 KiB) Downloaded 1210 times
Re: Predator 2
What drive? Internal, external powered by USB, external powered by separate power supply?
SOME of the error progression is similar to a USB-powered drive spinning too fast for it available power, but it is also similar to a drive that is trying too hard to read a sector, and the operating system is timing out waiting for it to respond:
There are some drives that try really hard to not return a read error. They'll return "looks almost valid" data if they can read most of a sector. MakeMKV checks for validity, and outputs debug codes when the data doesn't make sense. While I cannot say for certain that the debug codes reported mean that (only Mike, the program's author, knows the debug codes), it would be my first suspicion.
This is why the "go to" answer is cleaning the disk with a soft, damp cloth. Unreadable sectors can be as simple as a fingerprint or even just a "haze" on the disk surface. It doesn't even have to be obvious to our eyes; we don't look at them with a precisely-focuses laser trying to differentiate between layers of dots...
beatsntoons
Re: Predator 2
Yeah I've cleaned this disc ad nauseum now. It's definitely beyond clean, you could eat your breakfast off it.
Drive is an ASUS BW-16D1HT, internal. I've thought about power supply to it, so I just ran the entire system stripped down but it still failed at the same points. I'm going to test another disc in the morning (one I've successfully ripped) and if it works, I'm going to try get another replacement for Predator 2. Should be fun.
If that fails, I'm going to plug in an older PSU to see if my current PSU is not delivering power properly... and will try replacement cables, I think I have a few spares (I did sort of try this tonight by switching the cables around but nothing helped)
beatsntoons
Re: Predator 2
Far out. Got a new disc, inserted it, and MakeMKV won't open the disc
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.00' at offset '30531319808'
Did a test on some CDs and Blu-rays, they're fine, it's just this 4K title I'm having no luck on (still running 1.12.2, will go back to 1.12.3 shortly)
I can see the contents in Windows Explorer. I'm going to try and copy the files manually (again) and see how that goes.
st4evr
Re: Predator 2
Post by st4evr »
Do you have access to other UHD BD ripping software?
As much a fan of MakeMKV that I am in some cases trying other software can either yield a succesful rip or further information to the problem.
beatsntoons
Re: Predator 2
No I don't, I'm afraid. I tried an install of AnyDVD, but apparently I've already used my trial up, can't remember when.
I bought American Assassin and Murder on the Orient Express today.
Murder on the Orient Express ripped fine. I'm currently ripping American Assassin.
It looks like it really is something to do with Predator 2 that is causing my system to fail.
beatsntoons
Re: Predator 2
I'm completely confused.
Now the disc won't even be read. I plug it in, Windows won't even acknowledge a disc is in the drive, Explorer just hangs. MakeMKV won't pick up anything in the drive either. I've stripped out anything from my PC on the SATA ports to ensure only my OS, spare HDD (a different one each time to record to) and the ODD are connected.
This is the 3rd Pred2 I've picked up. Disc is completely clean.
I take the disc out, put American Assassin back in, bingo that disc works fine.
WTF is going on with Predator 2.
st4evr
Re: Predator 2
Post by st4evr »
Well that’s the thing. Sometimes some apps can handle some discs better than others. This is from experience. Hence why I asked.
I always recommend to have more than one ripping app just in case. I know some cost more than others, so in the end it’s up to each individual.
beatsntoons
Re: Predator 2
I have an external caddy coming for my ODD, so I can strip it out of my PC.
When that arrives, I've got a couple of Surfaces and another laptop I can connect it to so I can re-try AnyDVD on those. We'll see if they do a better job.
I'm still not entirely convinced it's MakeMKV at fault here because Windows now takes about 5 minutes to recognise the disc without any interaction from MakeMKV. Maybe a fresh PC will be a better option.
beatsntoons
Re: Predator 2
Still waiting on my caddy to arrive, but today I ripped Blue Planet II successfully. Tried Predator 2 again, nope. Got a java error when it first loaded too.
Disc opened fine and started ripping, then died halfway through.
Using Java runtime from C:/Users/[me]/Downloads/jre-10.0.2_windows-x64_bin.exe
DEBUG: Code 0 at 0w'lCiX{;0xMA}J8`*:29401750
DEBUG: Code 0 at 0w'lCiX{;0xMA}J8`*:213129961
DEBUG: Code 0 at )uiQGA=K"".ohLA%@&Cn:121264648
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00685.m2ts' at offset '28166455296'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '28166455296'
DEBUG: Code 3221225628 at /SJoTo5:0-tm*WgK=z:121262969
DEBUG: Code 100864261 at /SJoTo5:0-tm*WgK=z:121262969
DEBUG: Code 0 at k%b$mnt,in%nSSf:3K-<:121263176
DEBUG: Code 0 at `8z^V8+w"N"f]~:!iK"F:29394068
DEBUG: Code 0 at k%b$mnt,in%nSSf:3K-<:29394551
DEBUG: Code 13753152 at k%b$mnt,in%nSSf:3K-<:29393286
DEBUG: Code 0 at 7(:bJRPje>S[z:y!Z~".~:121267661
