Makemkv said something about dvd fab being used on the disc, then had to use direct disc access mode to do its thing.
This is naruto uncut season one box set vol.1 from shonen jump. Did I end up with a fake? bad discs? anyway to speed up direct disc access? You did sometype of log file?
Thanks for your help.
Naruto uncut box set season 1 vol 1 error or fake?
NoobageEncoder
Re: Naruto uncut box set season 1 vol 1 error or fake?
It's really hard to say - where did you buy them from?
MakeMKV said the same thing about almost every disk of Castle (purchased through Amazon). Why, I don't know. As far as I could tell, they were legitimate disks published by ABC, but they apparently had characteristics of a DVDFab rip that was re-authored.
Is this a set purchased from Japan (direct from Shonen Jump) or the Viz Media set?
