The Dark Knight Trilogy - The Dark Knight Rises
audioguy
I am on my 2nd copy of this disc and still will not rip. I have used three different drives (ASUS and two different model number LG's which have all worked previously) and nothing works. The other 2 discs in the set rip without incident.
Any ideas?
Any ideas?
st4evr
Re: The Dark Knight Trilogy - The Dark Knight Rises
The error log output or any additional information presented by MakeMKV when you run into this problem can be of great help in trying to identify the problem. Simply saying "it does not work" does not help us help you.
audioguy
I assumed that would be the case.
Isn't there a setting in preferences that allows the system to store the error log somewhere? I could not locate that so the best I could have done would be to copy and paste from the screen.
If I can set it up so it will capture the log I can then post again.
audioguy
I will try to run again and capture all of the error logs but I did get about a bazillion of these:
DEBUG: Code 2281701379 at 8#L6D"D`=7;p&.e`:213134837
audioguy
Tried again on another computer and got the following: (Got the same "upgrade your hard drive" message on my other computer and both use SSD, no hard drives. The drive I am trying to use is the ASUS drive.
Frustrating!!
Saving 1 titles into directory /Volumes/Movies/Next Up/The Dark Knight Rises 4K
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '42539286528'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '42539286528'
DEBUG: Code 1073741829 at C\ko6"6e4G[|2pu hj:121262969
DEBUG: Code 101000192 at C\ko6"6e4G[|2pu hj:121262969
DEBUG: Code 0 at %8l<+:H+LE1l#8uL]$"g:121263176
DEBUG: Code 0 at x2N,M/v(V$NcACvG1SY+:29394068
DEBUG: Code 0 at %8l<+:H+LE1l#8uL]$"g:29394551
DEBUG: Code 20771136 at %8l<+:H+LE1l#8uL]$"g:29393286
DEBUG: Code 0 at FT9IW5Y^n)ON0.5Ym]6ZP:121267661
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 1 to file /Volumes/Movies/Next Up/The Dark Knight Rises 4K/Dark_Knight_Rises_t01.mkv
0 titles saved, 1 failed
Frustrating!!
audioguy
Another attempt with different error messages. Again, if these error messages are stored in a file that I could attach and I knew where that file was,I would attach it.
The message: "http://www.makemkv.com/errors/hashcheck/..." implies a failing drive. But this drive has only been used a few times.
MakeMKV v1.12.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/chuckgerlach/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.02d" opened in OS access mode.
Downloading latest SDF to /Users/chuckgerlach/Library/MakeMKV ...
Downloading latest HK to /Users/chuckgerlach/Library/MakeMKV ...
File 00002.mpls was added as title #0
File 00009.mpls was added as title #1
File 00010.mpls was added as title #2
File 00011.mpls was added as title #3
File 00032.mpls was added as title #4
File 00033.mpls was added as title #5
File 00036.mpls was added as title #6
Title 00020.mpls is equal to title 00033.mpls and was skipped
Title 00034.mpls is equal to title 00033.mpls and was skipped
File 00000.m2ts was added as title #7
File 00004.m2ts was added as title #8
File 00005.m2ts was added as title #9
File 00006.m2ts was added as title #10
File 00007.m2ts was added as title #11
DEBUG: Code 1122 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1123 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1124 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1125 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1126 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1127 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1128 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1129 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1130 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1131 at x2N,M/v(V$NcACvG1SY+:29397403
DEBUG: Code 1 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 2 at x2N,M/v(V$NcACvG1SY+:213131318
The source file '/BDMV/STREAM/00012.m2ts' is corrupt or invalid at offset 61440, attempting to work around
DEBUG: Code 3 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 4 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 5 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 6 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 7 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 8 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 9 at x2N,M/v(V$NcACvG1SY+:213131318
DEBUG: Code 10 at x2N,M/v(V$NcACvG1SY+:213131318
Hash check failed for file 00012.m2ts at offset 190464, file is corrupt.
File 00012.m2ts was added as title #12
File 00016.m2ts was added as title #13
File 00021.m2ts was added as title #14
File 00026.m2ts was added as title #15
Encountered 1 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
gonca
Try using the previous version (1.12.2)MakeMKV v1.12.3 darwin(x64-release) started
audioguy
How does one access the previous version?gonca wrote: Tue Sep 11, 2018 8:15 pmTry using the previous version (1.12.2)MakeMKV v1.12.3 darwin(x64-release) started
Link to old versions in my sig.
audioguy
Thank you. I will give that a go and see if I can make any progress.
audioguy
Prior to downloading the older version, I decided to give it one more go. I washed the disc with soap and water, rinsed very carefully and thoroughly . Then I blotted dry with a brand new micro fiber cloth. And it worked perfectly (slowly, but perfectly). I had done the same previously but with a previous used micro fiber cloth and that didn't work!!
Thanks for all of your support.
Blotting dry? I've never done that... And I don't think it is recommended.
An article found by Lovely Rita, and linked in the "if you experiencing ripping problems" topic:
http://www.discwizards.com/articles/How ... -Discs.htm
Krawk
Any time I have had Hash Check errors I have usually ripped the entire disc to an image, then ripped from the image. Not sure why that works. Anyway, glad you figured it out this time.
mikesway
Does anyone know if ripping the 4K versions of the dark knight trilogy will also retain the IMAX parts of the movies? I know ripping a regular blu ray does not and am wondering if I should even bother trying to rip the 4K discs.
I'm very confused by your comment about the blu-ray. MakeMKV rips what's on the disc as is. The IMAX frames are baked in and nothing special going on there. The same will be true of UHD. I've ripped them all both blu-ray and UHD to MKV format and it retained everything as expected.
