Zatoichi: Darkness Is His Ally
stuckinkodiagain
Post by stuckinkodiagain »
Hey all,
I’m having trouble ripping the newly-released “Zatoichi: Darkness Is His Ally” blu-ray. (Please note that this is the 26th Zatoichi film just released by Tokyo Shock, and was NOT part of the massive Criterion Zatoichi set due to rights issues.) It successfully decrypts, but fails every time and doesn’t give me an error message. It just fails. The disc looks clean, and I’ve tried cleaning it, but no luck.
Anyone else having this issue?
For reference, it’s this disc:
https://www.amazon.com/dp/B07FNTN7JS/re ... LBbSRAYPSA
Thanks for your help!
Re: Zatoichi: Darkness Is His Ally
Kind of hard to figure out what is going on - you say it decrypts, and yet it fails.
Do you have debug logging turned on? (FAQ link in my signature explains it if you don't already have it turned on)
Are you doing "backup", or "Open/save as MKV"?
stuckinkodiagain
Open/save as MKV.
I’ll turn on debug logging and try sending a dump later tonight. I’ll also give the backup a whirl, if that fails.
mutiny8
Post by mutiny8 »
Same issue here with same title. Have tried 2 copies, same issue both times. It decrypts, but errors out shortly after starting.
mutiny8
Post by mutiny8 »
I've no idea how/what, but this appears to be fixed in in 1.14.2 for this title.
cheers!
