In ide mode and the win7 recognizes and can open the DVD driveBillycar11 wrote: Fri Sep 07, 2018 1:10 ammaybe dos flash does not support your sata controller. you are in ide mode right not ahci/raid?the_darkwater wrote: Fri Sep 07, 2018 1:06 amRedownloaded same thing and name says no atapi device presentBillycar11 wrote: Thu Sep 06, 2018 10:01 pm
uuuhhhhmmm did you unzip the folder? maybe just try re downloading it and unzipping it again if you did
the_darkwater
yeah i dont have a list of dos flash supported controllers but the next step would be to try another pe image of 32 bit windows i really dont like the one supplied here and i dont use it. if that dosent work you might have to send it out to be flashed and i do do that
timmeh
Darkwater - make sure that your drive is plugged into the one of the first 2 SATA ports. I had this same problem at first. It worked perfectly after that.the_darkwater wrote: Fri Sep 07, 2018 1:06 amRedownloaded same thing and name says no atapi device presentBillycar11 wrote: Thu Sep 06, 2018 10:01 pmuuuhhhhmmm did you unzip the folder? maybe just try re downloading it and unzipping it again if you did
the_darkwater
Worked THANK YOUtimmeh wrote: Fri Sep 07, 2018 1:31 amDarkwater - make sure that your drive is plugged into the one of the first 2 SATA ports. I had this same problem at first. It worked perfectly after that.the_darkwater wrote: Fri Sep 07, 2018 1:06 amRedownloaded same thing and name says no atapi device presentBillycar11 wrote: Thu Sep 06, 2018 10:01 pm
the_darkwater
question i dont see an 0x1E84FF is 001E84F0 okay?timmeh wrote: Fri Sep 07, 2018 1:31 amDarkwater - make sure that your drive is plugged into the one of the first 2 SATA ports. I had this same problem at first. It worked perfectly after that.the_darkwater wrote: Fri Sep 07, 2018 1:06 amRedownloaded same thing and name says no atapi device presentBillycar11 wrote: Thu Sep 06, 2018 10:01 pm
dont hex edit why do you all try it the hard way use the data mover if you cant use it for whatever reason send me your original dump Billycar5924@gmail.comthe_darkwater wrote: Fri Sep 07, 2018 2:29 amquestion i dont see an 0x1E84FF is 001E84F0 okay?timmeh wrote: Fri Sep 07, 2018 1:31 amDarkwater - make sure that your drive is plugged into the one of the first 2 SATA ports. I had this same problem at first. It worked perfectly after that.the_darkwater wrote: Fri Sep 07, 2018 1:06 am
Digital moe
If they are like me they don't read all the way to the bottom of the original post and assume it's a step that needs to be done.Billycar11 wrote: Fri Sep 07, 2018 2:40 amdont hex edit why do you all try it the hard way use the data mover if you cant use it for whatever reason send me your original dump Billycar5924@gmail.comthe_darkwater wrote: Fri Sep 07, 2018 2:29 amquestion i dont see an 0x1E84FF is 001E84F0 okay?timmeh wrote: Fri Sep 07, 2018 1:31 am
eng050599
Just wanted to mention that this method is still working perfectly, and I was able to flash two BW-16D1HT drives from 3.03 to 3.01. Both are reading UHD discs without issues.
As a small note, if you have an older PC laying about, take a look in BIOS to see if it only allows IDE. This was the case for an older Win 7 PC I had laying about, and I was able to read and write the drives without needing to make any changes to BIOS.
Porki
Is there any of you folks from Germany whom I could send my BW-16D1HT to and would be so kind to downgrade the firmware for me?
My motherboard is AM4 based and offers no IDE mode...
Mysus456
I have a new Asus 16D1HT
SCSI\CdRomASUS____BW-16D1HT_______3.03
1) What is the target firmware for UHD friendly reads? FW 3.0, 3.1, or 3.2?
2) Is DOSFLASH32_BH16NS40.exe a tool for Asus drives also?
3) Does the Win7-PE include the calibration data in one step - as well as to fix the "Drive Signature DV value" or "Bus Encryption"?
TeddyRaspin
1) 3.01 or 3.02 modded fw make your unit to be UHD friendly.
2) Yes, it supports any MediaTek MT1939/MT1959 chipset (mainly LG, ASUS).
3) Win7-PE, as the name suggests, is a Windows 7 Portable Edition, which is needed to properly execute DOSFLASH32.
If you carefully read my own guide, you'll find any answers for yourself.
moklinowski
Just signed up to thank the help to have a brand new UHD-friendly drive. Firstly, to TeddyRaspin, and all contributors as well.
My case:
- MoBo: Asus Gryphon Z-87; 2013; BIOS lets IDE mode, enable CSM (though boot override can be made also)
- Asus BW-16D1HT bought at Amazon Spain a few days ago
- FW: 3.03; as expected, all discs playable but UHD
Steps followed for Windows variation. Now with a 3.02 "combined" fw.
UHD tested successfully.
Thanks.
My case:
Thanks.
jonghotti
3.01 and 3.00 work as well.
As far as I can tell there’s no difference between 3.01 and 3.02. at least speed wise.
And for that matter the Asus firmware run on the lg drives is producing the same results as it does on the Asus labelled boxes.
It makes sense but it’s still blowing my mind.
Mysus456
Thanks for the confirmation. Though PE stands for preboot environment (it replaced sysprep for customizing Win7 images for deployment).TeddyRaspin wrote: Sun Sep 09, 2018 7:16 pm 1) 3.01 or 3.02 modded fw make your unit to be UHD friendly.
If you carefully read my own guide, you'll find any answers for yourself.![]()
Being a new drive w 3.03, and NO UHD read support. can someone confirm the windows 7 option will complete my objective of a UHD friendly with this 3.02 firmware ?
viewtopic.php?f=16&t=16885&start=75#p59568.
[I'll use the linked clean firmware with BH16NS40_EEPROM_Data_Mover.exe with my 3.03 dump to get my drive "OEM" as calibrated, "Drive Signature DV value", "Bus Encryption", etc. ready?]
Forgive me, but I want to be 100% certain before I move forward. [looks so, but Im seeing conflicting info on the target firmware]
jonghotti
Everything teddy says is Gospel I’ve used the win 7 pe stick to crossflash over 50 units in the last two weeks and have 26 more sitting here.
