Adding AAC conversion to custom profile?
casperse1
Post by casperse1 »
Hi All
I have used MakeMKV for many years and I bought it after a week :D
My main goal was and is to archive my DVD collection without any quality diminishing
But I wanted DK subs to be standard and all audio tracks as original
BUT I have noticed how well AAC works when streaming with PLex and I would like to get some help in incorporating this into my profile?
-5:(forced*(eng)),-5:(eng),-10:(dan),-15:(forced*(dan))
I have created a new profile : C:\Users\admin\.MakeMKV\my_aac-st.mmcp.xml
And I found this as the AAC profile, but I need to include all the org traks also, looks like this profile also converts surround to 5.1 AAC?
How can I incorperate my profile :
With the below one:
app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang|single),+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang"
In my new my_aac-st.mmcp.xml file?
<?xml version="1.0" encoding="utf-8"?>
<profile>
<!-- profile name -->
<name lang="eng">AAC-stereo</name>
<!-- Common MKV flags -->
<mkvSettings
ignoreForcedSubtitlesFlag="true"
useISO639Type2T="false"
setFirstAudioTrackAsDefault="true"
setFirstSubtitleTrackAsDefault="true"
setFirstForcedSubtitleTrackAsDefault="true"
insertFirstChapter00IfMissing="true"
<!-- Settings overridable in preferences -->
<profileSettings
<!-- Output formats -->
<outputSettings name="copy" outputFormat="directCopy">
<description lang="eng">Copy track as is</description>
<description lang="ger">Track 1:1 kopieren</description>
</outputSettings>
<outputSettings name="aac" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 AAC-LC</description>
<extraArgs>codec=libfdk_aac profile=LC</extraArgs>
<extraArgs>afterburner=1</extraArgs>
</outputSettings>
<outputSettings name="he-aac" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 HE-AAC</description>
<extraArgs>codec=libfdk_aac profile=HE-AAC signaling=explicit_sbr</extraArgs>
</outputSettings>
<!-- HE-AACv2 - stereo inputs only -->
<outputSettings name="he-aacv2" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 HE-AACv2</description>
<extraArgs>codec=libfdk_aac profile=HE-AACv2 signaling=explicit_hierarchical</extraArgs>
</outputSettings>
<outputSettings name="aac-gpl" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 AAC-LC (ffmpeg encoder)</description>
<extraArgs>codec=aac -strict -2</extraArgs>
<extraArgs>aac_coder=twoloop</extraArgs>
</outputSettings>
<!-- Audio downmix settings -->
<audioMixSettings name="stereo16"
outputBPS="16"
outputChannelLayout="stereo"
mix="DolbyPrologic2">
<description lang="eng">Stereo 16-bit Dolby PrologicII downmix</description>
</audioMixSettings>
<audioMixSettings name="stereo16raw"
outputBPS="16"
centerMixLevel="-3dB"
surroundMixLevel="-6dB"
lfeMixLevel="0">
<description lang="eng">Stereo 16-bit downmix</description>
</audioMixSettings>
<!-- Default rule - copy as is -->
<trackSettings input="default">
<output outputSettingsName="copy"
defaultSelection="$app_DefaultSelectionString">
</output>
</trackSettings>
<!-- For all audio tracks keep the original track
and produce additional AAC stereo downmix -->
<trackSettings input="LPCM-stereo">
defaultSelection="$app_DefaultSelectionString,-sel:all">
</output>
<output outputSettingsName="aac"
</output>
</trackSettings>
<trackSettings input="LPCM-multi">
</output>
audioMix="stereo16">
</output>
</trackSettings>
<trackSettings input="TRUEHD-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="TRUEHD-multi">
</output>
</output>
</trackSettings>
<trackSettings input="MLP-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="MLP-multi">
</output>
</output>
</trackSettings>
<trackSettings input="DTSHDMA-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="DTSHDMA-multi">
</output>
</output>
</trackSettings>
<!-- Save DTS-HD LBR (low quality) as AAC (just to decode),
do not keep original track -->
<trackSettings input="DTSHDLBR-stereo">
</output>
</trackSettings>
<trackSettings input="DTSHDLBR-multi">
</output>
</trackSettings>
<trackSettings input="DTS-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="DTS-multi">
</output>
</output>
</trackSettings>
<trackSettings input="AC3-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="AC3-multi">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-core-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-core-multi">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-multi">
</output>
</output>
</trackSettings>
<!-- Keep stereo AAC unchanged, add downmix for multichannel -->
<trackSettings input="AAC-stereo">
</output>
</trackSettings>
<trackSettings input="AAC-multi">
</output>
</output>
</trackSettings>
</profile>
Again thanks for any help you can provide making it easier to transcode with Plex to other mobile devices
casperse1
Re: Adding AAC conversion to custom profile?
Post by casperse1 »
I have tried just substituting the settings, but it dosent work
I need DK subs as default and the new AAC also to the default and keeping all original Subs and Audio tracks in the MKV?
casperse1
Post by casperse1 »
Still not there.....
<mkvSettings
ignoreForcedSubtitlesFlag="false"
setFirstAudioTrackAsDefault="false"
setFirstSubtitleTrackAsDefault="false"
setFirstForcedSubtitleTrackAsDefault="false"
<profileSettings
app_DefaultSelectionString="+sel:all,+sel:audio,+sel:lossless,-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-5:(forced*(eng)),-5:(eng),-10:(dan),-15:(forced*(dan))"
casperse1
Post by casperse1 »
So close now!
I have all tracks selected as default and I have DAN as default Sub!
BUT the new AAC track is not default it keeps defaulting to the AC3 track?
<profile>
<name lang="eng">MY-AAC-stereo</name>
<mkvSettings
<profileSettings
app_DefaultSelectionString="+sel:all,+sel:(mvcvideo),-sel:(havemulti|havecore),+sel:(lossy),+sel:(attachment),=100:all,=95:eng,=90:dan"
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
outputBPS="16"
</audioMixSettings>
outputBPS="16"
lfeMixLevel="0">
</audioMixSettings>
</output>
</trackSettings>
defaultSelection="$app_DefaultSelectionString,+sel:all">
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</output>
</trackSettings>
</profile>
casperse1
Post by casperse1 »
SO - Anyone how do I get the new AAC track to be the default (I am keeping the old AC3 and it keep being set as the standard track?)
The blow profile is working EXCEPT for the AAC to be the new standard track?
<mkvSettings
<profileSettings
app_DefaultSelectionString="+sel:all,+sel:(mvcvideo),+sel:lossy,-sel:(havemulti|core),+sel:(attachment),=100:all,=95:eng,=90:dan,=75:(forced*(dan))"
Any help would be greatly appreciated :oops:
Moved to the appropriate topic for modifying profiles.
What you are looking for is easier to do with other tools, like handbrake or even mkvmerge.
When you want to force a specific track to be played by default, it is important to make sure it is the FIRST track of its type (audio, subtitle, whatever) for maximum compatibility. Many players IGNORE flags, in favor of track order.
MakeMKV is not particularly good about moving tracks around like that. The profile settings allow you to select conversion, but it does not choose the track order directly.
Personal recommendation: Have MakeMKV rip all tracks for a title, and re-arrange their order with either handbrake or mkvmerge.
casperse1
Post by casperse1 »
I like to have my DVD is org format so I don't want to use handbrake, and I know that MKVToolNix can do it but it seems like double work :D
What about using the value in MakeMKV to have the new AAC track have a higher value than the org audio track?
It works great for subtitles so why not for Audio?
Setting first audio track "false" and using the "+sel:lossy" should move the audio track up right?
<mkvSettings
<profileSettings
app_DefaultSelectionString="+sel:all,+sel:(mvcvideo),+sel:lossy,=100:all,=95:eng,=90:dan,=75:(forced*(dan))"
If this is an impossible task in MakeMKV then please let me know, but sofar I have seen people do "impossible" things using the existing tools 8)
BTW this is for PLEX and sofar the default sub setting have been working perfectly, my hope is that audio would also function
Also the AC3 had a bitrate of:
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 47 min 14 s
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
The new AAC has a bitrate of:
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC-2
Bit rate : 140 kb/s
Is there anyway to bump it up to a minimum 192 kb/s in AAC?
casperse1
Post by casperse1 »
Bump....
No smart profile way to make AAC the default track in the MKV and the orig track second? ... :(
Any way to just select only ENG and DK to be converted to AAC?
Post by mike admin »
casperse1 wrote:
Sat Sep 15, 2018 1:40 pm
Bump....
Only seen it right now...
The way profiles work - firstly you specify all possible output per track type. This is done on track type basis (i.e. stereo, lpcm, etc). This is done on track settings level.
Then you select necessary tracks and assign order - this is done by selection rule (which can be specified in track setting as well). Since you have override for each track settings, you can specify track weight as well, forcing aac track to go up and original track to remain unchanged (or go down). Same for language selection - you have to specify AAC conversion for everything, MakeMKV will create AAC tracks for all languages, but you can specifiy custom selection logic in track setting causing these tracks to be always disabled for all languages except ENG and DK.
Paranoid Weirdo
Post by Paranoid Weirdo »
Hello everyone, sorry for stealing this post.
I'm new to makemkv & this forum.
I'm backing up my blurays but my TV only plays AAC audio.
If I use makemkv "default" it takes about half hour (but I can't hear sound)
If I pick aac profile it says its going to take over 20 hours.
What am I doing wrong?
All I want is to back up the movie in the best quality with aac sound, anyone help me?
Zynga
Post by Zynga »
@casperspe1
You can change the order by changing the order in the XML, just put AAC at the top
</output>
</output>
</trackSettings>
</output>
</trackSettings>
