Locked
#271 Post by Billycar11 » Wed Sep 05, 2018 6:59 am
michal wrote:
Wed Sep 05, 2018 6:49 am
Thanks for the kind offer. Meanwhile I flashed it to Asus 3.01, but if it is worth, I will send you my dump file.
Now the question is, how to upgrade from 3.01 to yours 3.02 ?
Thanks.
you would only need to flash it but let me dig something up for you this tool all you need to do is upgrade
TeddyRaspin wrote:
Wed Jan 17, 2018 8:41 pm
Asus 3.02 clean firmware with flasher (to allow crossflash or easy upgrade from previous versions).
there all easy now
urf it didn't put attachment you can just click up arrow to view original post or ill try to link attachment download/file.php?id=1252
michal
#272 Post by michal » Wed Sep 05, 2018 5:01 pm
Thanks for your help!
timmeh
#273 Post by timmeh » Thu Sep 06, 2018 11:16 am
I tried to follow the links for clean firmware from this part of the instructions:
"Select now a clean firmware to insert data (clean firmwares can be found here)."
All I seem to get is virus warnings and dead links on that page. Is it still active?
jlpsvk
#274 Post by jlpsvk » Thu Sep 06, 2018 11:39 am
Any help for me? I have Asus BW-16D1HT (originally 3.02), and accidentally flashed CLEAN FW to it.. now it does not read ANY media. Is there help for me or can I throw it to recycle bin? :D PS: avoid laughing.. i just stupidly missclicked. :(
TechNoApe
#275 Post by TechNoApe » Thu Sep 06, 2018 4:22 pm
Try this, it's the link from the guide for 'clean firmware'... https://www99.zippyshare.com/d/k7ZbMprP ... rmwares.7z
On the page that opens from the link, I didn't click on the 'Download' button, I right clicked and then selected copy link, and opened in another window... this went straight to the download ;-) You should just be able to click on the link above.
st4evr
#276 Post by st4evr » Thu Sep 06, 2018 7:09 pm
Well, you obviously bricked your drive. You can try this to see if you can "unbrick" it.
viewtopic.php?f=16&t=16885&p=65130&hilit=unbrick#p65130
Otherwise, buy a new one.
#277 Post by Billycar11 » Thu Sep 06, 2018 9:39 pm
do tell us if the unbricker works for you if not i have some stuff for you to try
the_darkwater
#278 Post by the_darkwater » Thu Sep 06, 2018 9:51 pm
I followed the steps but nothing how do I install portio32.sys
#279 Post by Billycar11 » Thu Sep 06, 2018 9:55 pm
u dont install it u need a 32 bit os
the_darkwater
#280 Post by the_darkwater » Thu Sep 06, 2018 9:58 pm
I'm using a USB with the windows image in the guide
#281 Post by Billycar11 » Thu Sep 06, 2018 10:01 pm
uuuhhhhmmm did you unzip the folder? maybe just try re downloading it and unzipping it again if you did
the_darkwater
#282 Post by the_darkwater » Thu Sep 06, 2018 10:21 pm
I unzipped I'll try again
the_darkwater
#283 Post by the_darkwater » Fri Sep 07, 2018 1:06 am
Redownloaded same thing and name says no atapi device present
#284 Post by Billycar11 » Fri Sep 07, 2018 1:10 am
maybe dos flash does not support your sata controller. you are in ide mode right not ahci/raid?
the_darkwater
#285 Post by the_darkwater » Fri Sep 07, 2018 1:14 am
Yup using gigabyte z87x-d3h ide mode
Locked
