The Equalizer
Trasper
The Equalizer
#1 Post by Trasper » Fri Aug 31, 2018 4:08 pm
The Equalizer won't rip. MakeMkv find the disc, but as soon as "the check box list" appear the player works hard for a few seconds, before a "no disc" message shows.
I believe it's something wrong with my disc, but since it's a Sony movie, I was wondering if it was the "Patriot/Fury thing".
Anybody had any problems with The Equalizer?
Thanx
gonca
Re: The Equalizer
#2 Post by gonca » Fri Aug 31, 2018 4:14 pm
One vote for no problems
Trasper
Re: The Equalizer
#3 Post by Trasper » Fri Aug 31, 2018 7:47 pm
Thank you!
Then it's my disc.
Gonna ask the store to take mine back, and give me a new one.
Trasper
Re: The Equalizer
#4 Post by Trasper » Tue Sep 04, 2018 12:58 pm
Got a new disc today.
Same problem.
Any idea what's wrong?
Re: The Equalizer
#5 Post by Woodstock » Tue Sep 04, 2018 1:20 pm
Not without more information than "it doesn't work".
Debug log (FAQ link in my signature) would go a long way towards providing the information to make guesses at "what's wrong".
rivey
Re: The Equalizer
#6 Post by rivey » Tue Sep 04, 2018 1:55 pm
Agree with Woodstock.
Also, did you clean the disc? Many times this helps even though the disc "looks" clean. Use a solution of 50/50 water and rubbing alcohol with a clean microfiber cloth. Clean a few times and try again. Good Luck
Trasper
Re: The Equalizer
#7 Post by Trasper » Wed Sep 05, 2018 1:12 pm
Thank you for the replies.
Now I got two The Equalizer 4k discs. (The store let me keep the old one, in addition to give me a new).
Same problem with both.
The disc take longer than usual to load.
Make MKV finds the disc, but when it gets to where you check/uncheck audio tracks and subtitles, the option to check/uncheck is showing just for a few seconds, then a "No disc" is showing.
I've cleaned both disc, same result.
The blu-ray version of the movie works fine, so do other UHD discs, so it has to be the discs.
One disc to fail, it happens, but two?
Maybe I got both from a bad batch.
Gonna give it a new try later.
gonca
Re: The Equalizer
#8 Post by gonca » Wed Sep 05, 2018 11:26 pm
Try using ImgBurn
Won't decrypt so image will have limited value, still would be non decrypted image, but see what it reports in terms of read errors or retries
Trasper
Re: The Equalizer
#9 Post by Trasper » Thu Sep 06, 2018 9:46 am
Thanx
Trasper
Re: The Equalizer
#10 Post by Trasper » Wed Oct 17, 2018 2:39 pm
The two The Equalizer I had was bought in England, as mentioned, both had the same problem.
Got a third from US today, ripping now and so far it seems to work fine.
Weird, since all three was bought new.
Anyway, happy it finally worked out.
Ryushin
Re: The Equalizer
#11 Post by Ryushin » Mon Dec 03, 2018 9:52 pm
I keep trying the US released UHD disc every few days. I keep getting the error about not being able to decrypt:
Backup failed
I email the dump file to svq@makemkv.com
Is that still the correct email address to send it to?
gonca
Re: The Equalizer
#12 Post by gonca » Mon Dec 03, 2018 10:28 pm
Ryushin wrote: Mon Dec 03, 2018 9:52 pm I keep trying the US released UHD disc every few days. I keep getting the error about not being able to decrypt:
Backup failed
Which version of MakeMVK are you on
Ryushin
Re: The Equalizer
#13 Post by Ryushin » Tue Dec 04, 2018 12:42 am
gonca wrote: Mon Dec 03, 2018 10:28 pm Which version of MakeMVK are you on
I'm on that latest I believe v1.14.2.
st4evr
Re: The Equalizer
#14 Post by st4evr » Tue Dec 04, 2018 5:09 am
Ryushin wrote: Mon Dec 03, 2018 9:52 pm I email the dump file to svq@makemkv.com
Yes, it is. How long ago did you send it? It can take a few days for support. It's not immediate.
Ryushin
Re: The Equalizer
#15 Post by Ryushin » Tue Dec 04, 2018 1:48 pm
st4evr wrote: Tue Dec 04, 2018 5:09 am Yes, it is. How long ago did you send it? It can take a few days for support. It's not immediate.
I've been sending the file every few days for the last couple of weeks.
