Hostiles - Playlist Obfuscation
cyberdman
Post by cyberdman » Mon Sep 03, 2018 3:34 pm
So I did a search on this title and I can't find any playlist that matches what has been posted. I also have my java set but for some reason with this disc it doesn't work and I get these output lines:
Using Java runtime from C:/Program Files (x86)/Java/jre1.8.0_171/bin/java.exe
DEBUG: Code 3 at XpAo^U5~|ihfRPN!ib:121263866
Failed to execute external program 'java' from location 'C:/Program Files (x86)/Java/jre1.8.0_171/bin/java.exe'
Then I am left with hundreds of titles and I just can't go through them all. Any ideas?
cyberdman
Re: Hostiles - Playlist Obfuscation
Post by cyberdman » Mon Sep 03, 2018 3:48 pm
Oh yeah, and it is the US retail version of the disc and I'm using MakeMKV version 1.12.3 for Windows.
hvnphoto
Post by hvnphoto » Mon Sep 03, 2018 5:22 pm
Playlist 00208.MPLS for US Retail.
cyberdman
Post by cyberdman » Mon Sep 03, 2018 9:41 pm
Thanks for the info, but I figured out how to make it work finally after a lot of trial and error.
I had the 32bit version of Java installed, but all of a sudden it stopped working with this version of MakeMKV. I had to manually download and install the 64bit version of Java and point MakeMKV to that and now it is working again.
Grauhaar
Post by Grauhaar » Tue Sep 04, 2018 6:17 am
cyberdman wrote: Mon Sep 03, 2018 9:41 pm and point MakeMKV to that
There is no need to specifiy the path in the preferences, MakeMKV always find a standard java installation. You should remove it from the preferences, because if you install a higher java version you must update the path.
Good Luck :)
