Die kleine Hexe Bluray (correct mpls?)
iMactouch
Post by iMactouch »
Hello!
Is the someone who knows the correct main title for the Bluray "Die kleine Hexe" (2018)?
On my Bluray there is title 21 with 10 chapters that is played, but this has nothing to to with the files used.
There is also Title 101 with 11 chapters which is in "Cinemascope format", but the correct title in makemkv could also not be found.
Any help is appreciated! Thank you!
super_dez
Re: Die kleine Hexe Bluray (correct mpls?)
Post by super_dez »
I bought my bluray copy of die Kleine Hexe from amazon.de... so assuming yours is the same, I used this method on youtube: https://youtu.be/AlhBmIbReao
and it showed 00663 as the correct mpls for the main title.
So I ripped 663 using makemkv and it seems to be right to me. Keep in mind I never saw the movie in the cinema but it seems cohesive and looks to be in the right order with no jumping around... so take that for what it's worth and give 663 a try.
Let me know if it works for you...
iMactouch
Post by iMactouch »
Thanks for the reply!
I will test it, but it is a little bit difficult as you have to see the whole film. :-)
I already send the neccessary files to support@makemkv.com but nothing happened so far.
super_dez
Post by super_dez »
Watching it now with my daughter and it seems good so far... 2/3 of the way through.
Feeling confident that it is indeed 663 at least for the Blu-ray that was purchased from amazon.de.
Good luck!
iMactouch
Post by iMactouch »
I looked at the bluray with the new 1.14.0, but it is still not working. No main title is shown.
iMactouch
Post by iMactouch »
Is there anything new regarding this Bluray?
There are three versions after I send the data, but still nothing has been changed.
Is sending the data still working?
Grauhaar
Post by Grauhaar »
I passed the data (Sep. 2018) to Mike and he answers:
This is a new generation of fakepls protection, MakeMKV cannot handle it
yet. I would very much like to get the backup, but please do make a backup
with 1.12.3 - it has new code specifically for this protection.
The requested addional data was send and that's all.
Good Luck :)
no-one
Post by no-one »
Better late than never, I can confirm that 663 is the correct playlist. It is the only one that has the first 4 segments in the correct order (503,500,508,507) and it matches the wide version found in 101 scene by scene
Fatal0l
Post by Fatal0l »
For me the following playlist worked:
00503
00500
00508
00507
00516
00506
00517
00502
00513
00509
00504
00519
00514
00510
00511
00512
00515
00501
00505
00518
