fake playlists - Three Musketeers (2011 - US Retail Amazon) - Java installed
tahlyn
Post by tahlyn »
Latest version of MakeMKV (1.12.3) and Java version is 1.8.0_181-b13, but no feature movie listed. It doesn't seem that Java is being invoked. Tried current version as well as 1.12.2 and 1.12.1 on 2 separate PCs (win10, MakeMKV, and Java; all latest updates). Same result.
Link to zip with non-decrypted full disc backup (minus stream folder) and log file.
http://s000.tinyupload.com/?file_id=180 ... 1095686410
thanks.
Re: fake playlists - Three Musketeers (2011 - US Retail Amazon) - Java installed
Post by d00zah »
tahlyn, just for grins, try adding the full path (including 'java.exe') under preferences > Protection. Restart MakeMKV & take another stab. Maybe Java's just not being detected automatically? Simple enough to try.
Grauhaar
Post by Grauhaar »
Java is only excecuted if needed, means the Blu-ray contains the relevant Java code for execution. MakeMKV shows the Java execution (with filename from where) or failure only in the Debug log and not in the MakeMKV info area.
Specification of Java in the preferences is only needed for special Java installations (only for Windows, no idea what is with Mac or Linux). MakeMKV detects a standard installation over the Windows registry and can find the location over this way.
Good Luck :)
Post by d00zah »
I'm aware. Although I rarely need it (& don't know that it's needed here), I noted that new versions of Java install to a version-specific folder, hence a path change with each update. In my limited testing, MakeMKV didn't always 'keep up', so I thought it worth verifying.
tahlyn
Post by tahlyn »
gave the custom path a try on both PCs, same result.
just to make sure Java detection was still working, I decided to pull out a couple of movies that had fake playlists that I had successfully saved before, John Wick and John Wick Chapter 2. When I spin up either disc in MakeMKV on either PC, I get this (with or without the custom path):
Using Java runtime from C:\Program Files\Java\jre1.8.0_181\bin\java.exe
and when they're done loading, I see the FPL_MainFeature for both, so I know the Java detection part is working.
I just think these particular movies with fake playlists that I'm posting (Source Code, Safe, Three Musketeers) haven't been added to some type of MakeMKV database yet, so hopefully they will soon. Thanks for the suggestion about the custom path.
tahlyn
Re: fake playlists - Three Musketeers Special Edition (2011 - US Retail Amazon) - Java installed
Post by tahlyn »
I tried another program and it displayed 17 "good" playlists which doesn't sound right. Of the 17 playlists listed by the other program, playlist 731 is missing in MakeMKV. Also in MakeMKV, of the 16 playlists that are listed in the other program, none have the same segment order. Some of the playlists are 2:21:02 (141 min). Case cover (barcode 2519213148, smaller number below barcode 66121390) says the movie is only 110 minutes (as well as many websites).
I went with 437 angle 1 based on this link:
viewtopic.php?t=4728
- 1:50:32 (110 min)
and watched the entire movie. 437 seems to be the correct playlist, at least for my disc (my bardcode and smaller number matched a user from the link above).
Total size: 23804064 sectors (46492 MBytes)
Video Blu-ray label: THREE_MUSKETEERS
Media is AACS protected!
Drive supports bus encryption!
AACS MKB version 27
Removed AACS copy protection!
Determined region(s): A
Blu-ray Java signatures fixed!
BD-Live deactivated!
Sony structural BD-J protection removed!
Java BD protection good playlists: 731, 796, 826, 631, 579, 532, 821, 756, 678, 688, 713, 468, 703, 437, 851, 376, 857
Bad sector protection not found.
MakeMKV
Name: Three Musketeers (English)
Source file name: 00437.mpls
Angle: 1
Duration: 1:50:32
Chapters count: 18
Segment count: 45
Segment map: 140,131,165,132,8,147,164,170,137,6,151,161,9,163,166,187,139,128,144,2,145,1,4,150,186,134,156,142,154,157,182,125,149,158,153,174,168,179,10,155,189,160,7,184,146
File name: Three_Musketeers_t41.mkv
