American Gangster (US Retail Amazon) - disc error - AV sync issue [SOLVED]
tahlyn
Post by tahlyn »
Has both the unrated and theatrical versions on one disc. The attached zip is for the unrated version. Both versions of the movie play fine on an Xbox One. Just want to know if it's disc errors or something else causing the issues.
thanks.
American Gangster.zip
(1.22 MiB) Downloaded 518 times
Re: American Gangster (US Retail Amazon) - disc error - AV sync issue
Did MakeMKV say it couldn't save the file?
AV sync messages are common on disk where multiple "cuts" exist, and they're more "informational" message than "must do something about" errors.
(no, I have not downloaded the ZIP and extracted it)
tahlyn
Post by tahlyn »
yeah, it ended with "0 titles saved, 1 failed." Here's the log:
004007:0010 AV synchronization issues were found in file 'C:/temp/American_Gangster_t05.mkv' (title #6)
004008:0010 AV sync issue in stream 1 at 0:00:00 with duration of 32ms : 3 frame(s) dropped to reduce audio skew to +9.708ms
004008:0010 AV sync issue in stream 1 at 0:00:00 with duration of 41.708ms : encountered overlapping frame, audio skew is +9.708ms
004008:0010 AV sync issue in stream 1 at 0:19:49.354 with duration of 0.791ms : encountered overlapping frame, audio skew is +10.5ms
001003:0020 DEBUG: Code 45045000 at n]b0~$o-o?V5vbG:khR:121265821
001003:0020 DEBUG: Code 0 at 7(:bJRPje>S[z:y!Z~".~:121267661
005003:0000 Failed to save title 5 to file C:/temp/American_Gangster_t05.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Thu Aug 30 18:24:35 2018
If you're using version 1.12.3, pull down the 1.12.2 version and try that. https://makemkv.com/download/old/
tahlyn
Post by tahlyn »
yep, it worked with 1.12.2. Still AV Sync errors in the log, but it saved successfully and could be played afterwards. Attached is the log. thanks.
MakeMKV_log.txt
(13.42 KiB) Downloaded 513 times
Re: American Gangster (US Retail Amazon) - disc error - AV sync issue [SOLVED]
Post by mike admin »
Confirmed bug in 1.12.3 . It fails (for subset of BD discs) if any subtitle track is selected.
