Deadpool 2
jmichaeljaffe
Deadpool 2
Post by jmichaeljaffe »
Deadpool 2 Blu-ray
ASIN: B07CF6X6XF
Format: Blu-ray, NTSC
Language: English
Subtitles: English, Spanish, French
Dubbed: Spanish, French
Region: Region A/1
Number of discs: 2
The disc set is brand new.
First disc is extended play (director's cut). This rips fine.
Second disc is theatrical version with extras. Disc won't open.
Protection is AACS v60
Insights would be greatly appreciated.
When Trying to open second disc, the following occurs on the log:
MakeMKV v1.12.2 win(x64-release) started
The new version 1.12.3 is available for download at http://www.makemkv.com/download/
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/MKB_RO.inf' at offset '14212'
Error 'OS error - This device does not exist' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/Unit_Key_RO.inf' at offset '0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/MKB_RW.inf' at offset '0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/Content000.cer' at offset '0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/Content001.cer' at offset '0'
Error 'OS error - This device does not exist' occurred while reading '/AACS/ContentRevocation.lst' at offset '0'
Saved AACS dump file as C:\Users\Michael/.MakeMKV/MKB_v60_Deadpool_2_DBFE.tgz
jmichaeljaffe
Re: Deadpool 2
Just noticed new MakeMKV version (1.12.3) available. Installed and got the same problem.
Attached is the AACS dump file, MKB_v60_Deadpool_2_DBFE.tgz
Log follows when trying to open second disc:
MakeMKV v1.12.3 win(x64-release) started
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Error 'OS error - This device does not exist' occurred while issuing SCSI command 280..001 to device 'SPTI:\Device\CdRom1'
Re: Deadpool 2
Is this an internal or external drive?
On the assumption that it's an internal drive (none of the power issues associated with USB drives), the error messages are consistent with the drive trying very hard to read a dirty disk, while the operating system is timing out.
jmichaeljaffe
Re: Deadpool 2
Woodstock wrote: Thu Aug 30, 2018 10:24 pm Is this an internal or external drive?
It is an external drive and it apparently was a power issue. I disconnected every other external USB device and the the disc opened with no problems. Never made the connection before, but now it makes perfect sense.
Many, many thanks!
