Hash Key file missing
~HaMMeR~
Post by ~HaMMeR~ »
The site hosting the Hash Key file says it's been deleted, is this something to be concerned about?
~HaMMeR~
Re: Hash Key file missing
Post by ~HaMMeR~ »
Thanks, but the ripping PC isn't connected to the Internet.
Has the manual download option been removed now then?
Post by d00zah »
So it would appear, but only Mike could say for sure. Seems reasonable that he would want to eliminate the need to manually update.
~HaMMeR~
Post by ~HaMMeR~ »
d00zah wrote: Thu Aug 30, 2018 1:22 pm So it would appear, but only Mike could say for sure. Seems reasonable that he would want to eliminate the need to manually update.
Maybe, but I bet I'm not the only one that uses an air gapped PC for ripping.
hernanez
Post by hernanez »
Also 1.12.3 is buggy and you need it for this feature. Another issue is how would one know if the disc is supported without the "manual" list? Try every few days and see if a key gets downloaded or not?
~HaMMeR~
Post by ~HaMMeR~ »
Was Deadpool 2 included in the last published hash key file? If so, would somebody be kind enough to share it with me?
st4evr
Post by st4evr »
The link to the manual downloaded key file is back up with an updated file. It appears Mike will continue to support this file/method until he advises otherwise.
~HaMMeR~
Post by ~HaMMeR~ »
st4evr wrote: Mon Sep 03, 2018 1:49 am The link to the manual downloaded key file is back up with an updated file. It appears Mike will continue to support this file/method until he advises otherwise.
Thanks st4evr, (and Mike), downloaded.
